RCUnlocker
  • peste
    • 12371
    • ROMANIA
    #1021
    Originally posted by Fred2
    I have a password-protected bios from an HP 650 G1. I have tried RCunlocker and it reads it and says it's unlocked, but it doesn't output a file. I've attached the dump file. Can I get some help or somebody to unlock the bios?
    read post #1.. the program works very well..
    • Fred2
      • Mar 2023
      Okay, I figured out my mistake. I had to re-download the RCunlocker and the re-downloaded .exe file worked. There's a whole day of frustration I'm not going to get back.
      • Kabel Salat
        • Apr 2024
        • Switzerland
        #1023
        Okay so I am unsure on what I did wrong but I've tried it on a 850 G5 and a 840 G6 both of which ended up with similar results, the G6 will endlessly blink the charge light white and yellow while caps locks lights up and the G5 blinks its charge light white and yellow for a while before turning to a constant white with both laptops now not turning on.
        I took off both laptops chips the 16MB one on the bottom and the 32MB one on the top of the board, made backups of each chip (and verified them), ran the 16MB chip through the program, flashed (and verified) the file and soldered it back onto the board yielding me with the before described result.
        Anyone know what I did wrong here ?
        • peste
          • 12371
          • ROMANIA
          #1024
          write the copy you made back on the chip and see if it's ok..
          • Kabel Salat
            • Apr 2024
            • Switzerland
            #1025
            That got both laptops turning on again, but with the BIOS lock back in place ofcourse
            • Kabel Salat
              • Apr 2024
              • Switzerland
              #1026
              Did some messing around with the dumps of the 16MB chip myself and after clearing out the two regions starting with NvramActiveRegn I actually got the laptop to turn on without a BIOS password However I get a Warning now that theres a problem with the security chip on the laptop (even after resetting the security settings in the BIOS), eh most likely deleted something I shouldnt have but for reference ive included the files here.
              • Marc735
                • Mar 2023
                • Deutschland
                #1027
                Hi, I have a HP Dragonfly G2 with a bios pw. I tried the U367 and U366 with the RCUnlocker, but it says "Wrong chip Try reading and unlocking 16MB chip". Could someone help me?
                Thanks a lot!
                Marc
                • peste
                  • 12371
                  • ROMANIA
                  #1028
                  Thanks a lot!
                  Marc
                  read...https://www.badcaps.net/forum/troubl...before-posting
                  • Marc735
                    • Mar 2023
                    • Deutschland
                    #1029
                    Oh sorry, I try it again.
                    I have a HP notebook with an unknown bios pw.
                    HP Elite Dragonfly G2
                    PRO: 25W56AV
                    SN# 5CG20260HS
                    I take a dump of the U366 and the U367 chip and tried to use the RCUnlocker, but it says "Wrong chip Try reading and unlocking 16MB chip".
                    Is there another chip with 16MB on the mainboard or did I use the RCUnlocker in a wrong way?
                    • BETEP555
                      • May 2024
                      • uruna
                      #1030
                      I bought hp_elite_x2_1012_g1 secondhand. I accidentally found out that the BIOS was blocked in it. I took it apart and found a Winbond 25q128fvpq flash drive, in an 8wson case similar to a BGA. I soldered the wires directly to the legs of the chip. I read the vvdi-prog dump. Clicked open with RCUnlocker.exe. the resulting file was written to the chip. laptop is unlocked. Thank you very much to the creator of this wonderful program!
                      I am attaching the dump, maybe it will be useful to someone​
                      • Marc735
                        • Mar 2023
                        • Deutschland
                        #1031
                        PRO: 25W56AV
                        SN# 5CG20260HS
                        The problem is solved. I found another way to unlock the bios.
                        • TAKKOdome
                          • Italia
                          #1032
                          Good morning, I used the RCUnlocker program but I can't unlock the password. I attach original file
                          PC HPZbook 17 G5
                          • deeptenk
                            • Sep 2023
                            • 10
                            • Belarus
                            #1033
                            Wrong chip. Try 16mb chip dump.
                              • 20477
                              PC HPZbook 17 G5
                              RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
                              You MUST:
                              • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                              • TAKKOdome
                                • Italia
                                #1035
                                I also tried the other file it tells me it's unlocked. But the password remains (Photo attached)
                                I also attach files Click image for larger version
                                • piszpunta
                                  • Jan 2019
                                  • 247
                                  • poland
                                  #1036
                                  try
                                  • rex98
                                    • Feb 2023
                                    • 1264
                                    • Mandaue CEBU, Philippines
                                    #1037
                                    here
                                    • star776688
                                      • May 2024
                                      hi i need help with admin bios unlock for hp 650 15.6" g9
                                      serial 5cd33241ro
                                      sku 85d70ea
                                      uuid b3cd28fe5631c14d84700451f3653929
                                      thanks
                                      • saeid1360
                                        • Jan 2024
                                        • 5
                                        #1039
                                        HI EVERY ONE I TRY RCUNLOCKER BUT IS NOT SUCSEE
                                        I Read bios file by ds-809se
                                        laptop model is hp probook 440 G7
                                        i attach dump file any one can help me ?
                                        i try defrent file as well but still need passwoord for restet bios
                                        SN: 5CD1025D5
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 11415
                                          • Viet Nam
                                          #1040
                                          SN: 5CD1025D5
                                          XXX
                                            HP Clean VSS2 dumps,fix Endpoint Security error
                                            by SMDFlea
                                            Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                            the infamous **"Endpoint Security" error message.
                                            Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                            I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                            The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                            files.
                                            hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                            filling everything after...
                                            08-08-2024, 03:14 PM
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
                                            HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:50 AM
