RCUnlocker
  • coucou63
    • Dec 2023
    • 9
    • france
    #961
    Does someone achieve to launch RCunlocker ? (i've got plenty of error ... VCRuntime140.dll , athen fter error 0xc000007b ... now python37.dll ... error 0xc00000428 ?
    • CammyTier1
      CammyTier1 commented
      Editing a comment
      it tells u ur a missing the py37.dll
  • kumquatscurrant
    • Jan 2024
    Hi folks,
    I'm just getting started with bios flashing. I'm looking into removing a password from an HP elitebook 845 G9. Looking at the motherboard, the most likely chip I've found so far is a MX25L25673GZ4I-08G, an SPI 32MB NOR flash chip. Has anyone used RCUnlocker with these 32MB chips? Perusing this thread, it seems like RCUnlocker has the limitation of only working with 16MB bioses? Should I be investigating an alternative tool for removing the password from this chip?
    Thanks you.
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      #963
      Yes.
      No.
      You can continue "investigating" off course, but there's no such tool. Dump your bios and upload the file to the existing HP EliteBook 845 G9 thread, and someone will do the unlock for you.
      Become a Badcaps supporter
      Thanks to all supporters.
      • kumquatscurrant
        • Jan 2024
        Thank you Vesko. I've done as you've said in https://www.badcaps.net/forum/troubl...itebook-845-g9. Appreciate the pointers.
        • XMEN
          • May 2011
          #965
          hello friends i need help to get rid of the password i tried hp unlocker is RCunlocker with no result i have never seen a bios like this​
        • Louis Beke
          #966
          hi, for my hp elitebook 755 g5 its not working from my bios file
        • Tom Boocock
          #967
          Hello, when I try to run Rc unlocker I get an error saying vcruntime140.dll was not found. Reinstalling the program may fix this problem
          • Mr.Nobody
            Retired
            • Apr 2022
            • 73
            #968
            This file is part of the Visual C++ 2015 Redistributable, which needs to be (re)-installed
            for 64 bit Windows:
            https://aka.ms/vs/17/release/vc_redist.x64.exe
            for 32 bit Windows:
            https://aka.ms/vs/17/release/vc_redist.x86.exe
            • Tom Boocock
              #969
              Thanks!
              • Tom Boocock
                #970
                Now it opens but it says missing file destination argument. Thanks
                • peste
                  • 13185
                  • ROMANIA
                  #971
                  I'm still getting the same response after re installing
                  you don't have to run or install the program.. you just have to drag (slide) the bios from it.. read the first page ...
                  • mkae
                    • Oct 2023
                    • Zambia
                    #972
                    i tried to unlock a 32mb bios for my zbook firefly 14 G7 but it failed. i have searched all internet but cant find solution. please help
                  • mkae
                    • Oct 2023
                    • Zambia
                    #973
                    Kindly help me how i can acquire the info like Serial number, motherboard model and revision. the covers on my zbook are for HP firefly G8 and my motherboard is G7
                    • peste
                      • 13185
                      • ROMANIA
                      #974
                      you should have a label on the case, the motherboard model is written on the board with white paint..
                      • mkae
                        • Oct 2023
                        • Zambia
                        #975
                        HP ZBook Firefly 14 G7 Base Model
                        Product: 8VK70AV
                        Serial: 5CG046C5S3
                        UNSPSC code: 43211503​
                        • danito
                          • Jun 2016
                          • 1046
                          #976
                          Product: 8VK70AV
                          Serial: 5CG046C5S3
                          Try
                          • mkae
                            • Oct 2023
                            • Zambia
                            #977
                            Originally posted by danito
                            Try
                            I downloaded, cleaned the bios and then flashed it. But,it still booted with password
                            • danito
                              • Jun 2016
                              • 1046
                              #978
                              try
                              • BisSumo
                                • cyprus
                                #979
                                im trying to remove bios password from hp2570P and when i run it thought rcunlocker i get this error see picture has anyone else had this
                                • peste
                                  • 13185
                                  • ROMANIA
                                  #980
                                  it's ok like that...you can write the bios chip with this content with an error....don't worry...be careful not to delete the content of the original bios (the one with the password) until you are sure that it works...
                                    HP Clean VSS2 dumps,fix Endpoint Security error
                                    by SMDFlea
                                    Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                    the infamous **"Endpoint Security" error message.
                                    Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                    I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                    The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                    files.
                                    hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                    filling everything after...
                                    08-08-2024, 03:14 PM
                                    HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                    This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                    09-07-2024, 07:12 AM
                                    09-07-2024, 06:40 AM
                                    HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                    This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                    09-07-2024, 05:50 AM
