Hi , i tried the TEST_2 file but result is the same. I can press F10 and get message 'entering setup menu'. After 10 minutes i press F1 and i get 'enterin system information' so laptops seems alive but stays in the last-message-screen.
---------------------------------------------------------------------------------------------------------------------------------------------------------- All donations to Badcaps are welcome. Become a Badcaps supporter >>>>>click on this link to donate <<<<< Thanks to all supporters. ----------------------------------------------------------------------------------------------------------------------------------------------------------
I obviously answer smiley60 since I'm quoting him in my post, and it's obviously is an answer to smiley60's problem.
It doesn't concern you in any way. There's no need to spam the topic!
thanks vesko but the problem not solved
but when i disable hp sure start the message gone
I think its must be some thing else
and i unlocked another hp 840 g5 and faced this problem again
I noticed this happen when the chip manufacture is issi
no problem with winbond or mxc
Actually what I wonder is that I cannot run the rcunlocker.exe, however
I can run hpunlocker.exe that you wrote. I tried with the locked bin file sent
by other.
They use completely different code so doesn't help much. Do you have all of the files in folder like they came from the rar or did you copy it somewhere else without other files included?
Hello there.
I have a HP Elitebook x360 1030 G3 that has its BIOS password protected.
If I understand correctly, the only way to attempt to unlock it is to dump the bios to a file and use your tool, and the only way to dump is physically with an adaptor clip to the BIOS chip inside my laptop. Correct? Or are there ways to dump the bios without physical / adaptor use.
