RCUnlocker
    Re: RCUnlocker
    Both are possible but I'd modify 16MB only.
      Re: RCUnlocker
      ok thank you, i will try tomorrow.
      How about Elitebook 850 G7?
        Re: RCUnlocker
        Again, both are possible but I support 16MB only right now. But back up 32MB aswell, just in case.
          Re: RCUnlocker
          Originally posted by maxitaxi View Post
          Hi , i tried the TEST_2 file but result is the same. I can press F10 and get message 'entering setup menu'. After 10 minutes i press F1 and i get 'enterin system information' so laptops seems alive but stays in the last-message-screen.
          Retoricalcheese, here is the 32mb file
            Re: RCUnlocker
            I will get back to you tomorrow
              Re: RCUnlocker
              not download bro can you share on here RCunlocker tool
              show this error
                Re: RCUnlocker
                I can confirm that the zip file download is working as of today.
                  Re: RCUnlocker
                  hi bro
                  i unlock 840 g6 but faced with hp endpoint security problem and it s come every time that i power on the laptop
                    Re: RCUnlocker
                    Originally posted by smiley60 View Post
                    hi bro
                    Enter the bios and reset security settings to default:
                    Become a Badcaps supporter
                    Thanks to all supporters.​
                      Re: RCUnlocker
                      What are the purpose of the 1 NEW.zip attachment?
                        Re: RCUnlocker
                        I obviously answer smiley60 since I'm quoting him in my post, and it's obviously is an answer to smiley60's problem.
                        It doesn't concern you in any way. There's no need to spam the topic!
                          Re: RCUnlocker
                          thanks vesko but the problem not solved
                          but when i disable hp sure start the message gone
                          I think its must be some thing else
                          and i unlocked another hp 840 g5 and faced this problem again
                          I noticed this happen when the chip manufacture is issi
                          no problem with winbond or mxc
                            Re: RCUnlocker
                            thanks!!!
                              Re: RCUnlocker
                              Hello RethoricalCheese,
                              I just want to confirm that I understand the process of Unlocking the BIOS AKA Clear BIOS Admin Password using your tool.
                              1 - I first need to read/exctract the current BIOS Config (BIN file) with the CH341a programmer with a SOIC8 SOP8 Test clip.
                              2 - Drop the extracted BIN file onto your RCUnlocker. It will do it magic and create a new BIN file.
                              3 - Using the CH341a programmer with a SOIC8 SOP8 Test clip, write back the new BIN onto the BIOS. The Admin password should be remove.
                              Is this the right step overall?
                              I have a HP EliteBook 820 G3 that I forgot the Admin password...
                              Cheers and thanks for your help!
                                Re: RCUnlocker
                                Exactly. But step 4 would be to reset security settings in bios.
                                  Re: RCUnlocker
                                  When drag the bin file to the exe file, I got this error message.
                                  The application was unable to start correctly (0x00007b).
                                  Did I make any mistake?
                                    Re: RCUnlocker
                                    Not sure. Upload your file, somebody can unlock it then.
                                      Re: RCUnlocker
                                      Actually what I wonder is that I cannot run the rcunlocker.exe, however
                                      I can run hpunlocker.exe that you wrote. I tried with the locked bin file sent
                                      by other.
                                        Re: RCUnlocker
                                        They use completely different code so doesn't help much. Do you have all of the files in folder like they came from the rar or did you copy it somewhere else without other files included?
                                          Re: RCUnlocker
                                          Hello there.
                                          I have a HP Elitebook x360 1030 G3 that has its BIOS password protected.
                                          If I understand correctly, the only way to attempt to unlock it is to dump the bios to a file and use your tool, and the only way to dump is physically with an adaptor clip to the BIOS chip inside my laptop. Correct? Or are there ways to dump the bios without physical / adaptor use.
                                          Appreciate your time
