RCUnlocker
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    #741
    Re: RCUnlocker
    Originally posted by il60
    Sorry really sorry
    thans for information for next time...
    Sn : C5CD051GMV8 yes, 650 g8
    yes i have password
    So now wait here if someone can help me ? or go ask on 650 G8 topic ?
    again, thanks for you"r help !
    Upload the image here, showing the password prompt screen.
    Become a Badcaps supporter
    Thanks to all supporters.
    • kekosef
      • Oct 2022
      Re: RCUnlocker
      Could you please unlock this BIOS please ?
      Just did a donation because you are all very helpful
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        #743
        Re: RCUnlocker
        Thank you very much for your support! Appreciate it!
        Here you are:
        • joe9041
          • Apr 2023
          • 8
          Re: RCUnlocker
          Let me start out praising @RhetoricalCheese for an awesome application. Thank you sir!!
          This is my first chip (ever) that I am reprogramming so please be patient. I pulled a Winbond 25Q256JVEN (2202) (6141) (GM400) chip out of an HP Elitebook 850 G8 hoping to wipe the Admin password from the bios. I am using a XGecu T48 [TL866-3G] programmer. The chip did not work with any of the connectors I had so I had to use the test clip that came with it. I was able to READ then VERIFY the chip. I can see ASCII info that was added. I then saved the bios .BIN file and moved it to the RCunlocker.exe. But...I keep getting the same error, "Wrong Chip. Try reading and unlocking 16 MB chip." I am not sure what to do to get around this. I have tried using both "W25Q256JV SOIC8 and W25Q256JV SOIC16" but with no luck. I appreciate any help or input you can give me.
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            #745
            Re: RCUnlocker
            Shouldn't be a problem but If you want the members here to help you, post your original backup (both dumps) and someone will do it for you.
            • joe9041
              • Apr 2023
              • 8
              Re: RCUnlocker
              That is awesome!! Appreciate any help
              I am including the original BIOS from an HP Elitebook 850 G8 - Could you please unlock this BIOS?
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #747
                Re: RCUnlocker
                Sure, but you uploaded only the main bios dump - I've said both, where is the dump from the second (EC) chip?
                • joe9041
                  • Apr 2023
                  • 8
                  Re: RCUnlocker
                  Sorry I was not aware there was a second (EC) chip that needed to be reprogrammed. Would you happen to know where this would be located? Maybe at the bottom of the board?
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #749
                    Re: RCUnlocker
                    Yes, it's at the back side of the board (U366).
                    • joe9041
                      • Apr 2023
                      • 8
                      Re: RCUnlocker
                      Thanks so much!!
                      Here are both the Main and EC bios files. I was able to extract the .BIN from the EC, but I thought it was weird that the software gave me a "Check ID" error. It told me to uncheck it and I then would be able to read/save the chip. When I scrolled through the ASCII section, I didnt see any characters like I did for the main chip read. The EC file is 32 MB.
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        #751
                        Re: RCUnlocker
                        Thanks so much!!
                        EC dump is completely empty (FF filled), so you should try to read the chip again, use verification. What programmer you are using, ch341a?
                        • joe9041
                          • Apr 2023
                          • 8
                          Re: RCUnlocker
                          I have tried it again and verified.
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            #753
                            Re: RCUnlocker
                            Well done. Much better attempt.
                            Below is your unlocked dump, program EC chip only (don't forget to erase it before programming), leave the other chip as is.
                            At the first boot enter the bios and reset security settings to default.
                            Then enjoy your unlocked toy, and don't forget to buy me a beer, you can do that by
                            making a donation in support of the "Bios Requests" section of the forum.
                            P.S. Just in case before all that take one more verified dump of the EC bios chip. Just to be on a safe side. I've checked your second read and it's looking perfectly fine, but as I said just in case, and for the sake of following the right procedure.
                            Leave feedback and Good Luck!
                            • joe9041
                              • Apr 2023
                              • 8
                              Re: RCUnlocker
                              Appreciate the help. But....I am getting this error when I program the EC. Help please!
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #755
                                Re: RCUnlocker
                                I don't know exactly what the problem is, most likely bad contact between the programmer and the chip. What is the connection type - wson8 to dip8 adapter or something else?
                                • joe9041
                                  • Apr 2023
                                  • 8
                                  Re: RCUnlocker
                                  I was able to program the original .BIN file back to the EC with no issues. I am using a tester clip socket.
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    #757
                                    Re: RCUnlocker
                                    So what's the problem then, program the unlocked file the same way.
                                    This "tester clip" as you call it is not intended for use with WSON8 SPI flash chip hence the problem. This clip is designed to be used with SOIC-8 SPI chip.
                                    So as I already supposed - your problem is a bad connection with the chip.
                                    • il60
                                      • Jun 2019
                                      • 25
                                      • France
                                      #758
                                      Re: RCUnlocker
                                      Sorry for late answer, you was right, i post the wrong bios laptop bios
                                      thanks for all !
                                      • aspenthedon
                                        • Apr 2023
                                        • 7
                                        • United states
                                        #759
                                        Re: RCUnlocker
                                        So I have a hp EliteBook 8470p with a Winbond 25Q128fvsq chip. I pulled the bin file from chip with exp2019+ and then I verified it. Everything appeared to be ok. So as I go to read it again every attempt to read chip shows chip is empty? What should I do from here? Any suggestion would be helpful. Also I've attached the original read I pulled. Thanks !
                                        • peste
                                          • 12365
                                          • ROMANIA
                                          #760
                                          Re: RCUnlocker
                                          yes, you wanted to delete his password, look at the bios here..
                                            HP Clean VSS2 dumps,fix Endpoint Security error
                                            by SMDFlea
                                            Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
                                            the infamous **"Endpoint Security" error message.
                                            Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
                                            I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
                                            The offsets and file sizes are part of the naming convention i`ve used for the extracted
                                            files.
                                            hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
                                            filling everything after...
                                            08-08-2024, 03:14 PM
                                            HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-07-2024, 07:12 AM
                                            09-07-2024, 06:40 AM
                                            HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-07-2024, 05:50 AM
