RCUnlocker
    Re: RCUnlocker
    Hello.I try to unlock some Notebooks with MiniProgrammer,CH341A and RC unlocker Tool.
    I am not professional in this case and need some help. What i have to do step by step.It will be great if some body can give me detailed instruction.
    Thanks a lot
    Regards Detlef
      Re: RCUnlocker
      Thanks a lot
      Regards Detlef
      https://www.badcaps.net/forum/showthread.php?t=103526
      Become a Badcaps supporter
      Thanks to all supporters.​
        Re: RCUnlocker
        Is there anyway to port this to Linux shell I dont use windows on the rpi and it gets tedious using windows
          Re: RCUnlocker
          Thanks a lot
          Regards Detlef
          Watch the video I posted in an earlier post - https://www.youtube.com/watch?v=QnlvlKuPMVk
            Re: RCUnlocker
            Hi guys, I have a Hp Probook x360 435 G7. I found a 32mb MXIC chip, and an Unknown size windbond 25W256JVEN chip when removing the cover. Do I have a 16mb chip on the under side of the motherboard? I am not going to be de soldering. I will be using the clip on programmer, so just asking if I need to remove the MB? Neither one of the chips Ive mentioned show up in the search in the software.
              Re: RCUnlocker
              If so your bios and ec are both 32MB type, no 16MB chip.
                Re: RCUnlocker
                So the unlocker will not work for me then?
                  Re: RCUnlocker
                  Obviously yes, just upload the files here, someone of us will do the job for you.
                    Re: RCUnlocker
                    You guys rock! I will do my best to get the files, but since they do not match any chip number, I will use the closest matching
                      Re: RCUnlocker
                      Here are my two files. Couldnt verify, as my chips arent in the list.
                        Re: RCUnlocker
                        Yes, you can:
                        https://www.badcaps.net/forum/showpo...8&postcount=52
                          Re: RCUnlocker
                          ok
                            Re: RCUnlocker
                            ok
                            Both are bad - ch341a?
                              Re: RCUnlocker
                              yes, and yes. on pass 8 trying to verify windbond
                                Re: RCUnlocker
                                Will not verify. Every pass verification goes to 25%.
                                  Re: RCUnlocker
                                  Its because the software is shit,and also i think its because the bios chips are WSON8, the clip will not fit onto them.If they are WSON8 then you will have to desolder or solder wires from the adapter board to the gold pads connected to each chip pin
                                  Use these software alternatives,you`ll find them all posted on the forum
                                  NeoProgrammer, Colibri, AsProgrammer
                                    Re: RCUnlocker
                                    I was wondering if the software is crap. Here is a pic of the chip. The clips seem to make good contact.
                                      Re: RCUnlocker
                                      Yes thats a WSON8 chip, don`t use the clip on that,you risk damaging the chip,shorting the surrounding components and cutting through traces.
                                      Your options are to desolder it,use a WSON8 pogo pin adapter,or try to solder some thin wires to the protruding solder or traces caps and resistors
                                      https://www.aliexpress.com/item/1005003313016522.html
                                        Re: RCUnlocker
                                        Ya, I may just bag the whole thing. I cant solder for sh1t. I bought the laptop second hand knowing it had a admin bios password. I am able to do a clean install of windows by pressing the f9 key at post to bring up which drive to boot from.
                                          Re: RCUnlocker
                                          My advice is to leave it as it is. You do not have enough experience and especially quality tools to do the job properly. It is possible to worsen the situation at this stage.
