Originally posted by antiogu
View Post
IdeaPad 3 14ADA5/15ADA05/17ADA05 Lenovo V14-ADA/V15-ADA Bios
OK so I've studied the procedure in particular with this video but I don't have a backup of my previous bios healthy, it's corrupt because it was badly flashed precisely.
https://youtube.com/watch?v=NyjflvtmAYA
So how can I start from scratch with an old blank bios and transfer my information to it to generate a special bios with custom dmi? Thanks
Originally posted by pblenov541 View Post
Can you send me same file with my informations please ?
Ideapad 3 15ADA05
MODEL name: 81w1
SN: PF3NTMCG
MTM: 81W1002GFR
https://www.youtube.com/results?sear...mer+how+to+use
Become a Badcaps supporter
Thanks to all supporters.
Ideapad 3 15ADA05
MODEL name: 81w1
SN: PF3NTMCG
MTM: 81W1002GFR
Ideapad 3 15ADA05
MODEL name: 81w1
SN: PF3NTMCG
MTM: 81W1002GFR
I'm having the same problem as you: no image, even though the PC seems to boot normally.
I hope this helps someone, as I've solved my problem.
If you've read this thread, try reprogramming the BIOS. You've checked, as others have indicated, that DIMM_only is enabled (presence or absence of resistor on the motherboard). So you may have the same problem as me.
At the SODIMM slot where the memory stick is inserted, the pins at the ends (left and right) were unsoldered.
A solder point, and the PC works perfectly.
Originally posted by SMDFlea View Post
Post your backup in a zip or rar ,attach it directly to your post, don`t post external links please.Attached Files
i attach rar file
Originally posted by antiogu View Post
Can anyone help me?
you have everything you need at post #341...Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
