la-b151p bios info transfer
  • mantza
    • Sep 2020
    • 36
    • GREECE
    hello, can someone copy my info from my old bios to the other one i got from hp?
    its working but it doesn't have my info and its with manufacture programming mode is in unlock mode
  • peste
    • 13924
    • ROMANIA
    Re: la-b151p bios info transfer
    try..
    • mantza
      • Sep 2020
      • 36
      • GREECE
      Originally posted by peste
      try..
      thanks, it worked, i still needed to edit with bcu the manufacture mode off but the info is ok
        Common SPI bios chip programming Questions and Answers
        by SMDFlea
        Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
        A: If you can`t read from it how do you expect to write to it ?.
        Q: Why is my bios chip unreadable ?.
        A: The programmer is faulty or has a worn or broken zif socket.
        The USB cable is frayed,connector pins worn or some other physical damage.
        Not enough amperage or voltage to power the programmer properly.
        Bad...
        09-02-2021, 04:40 PM
      • macabook
        by macabook
        🧩 Initial Issue
        07-24-2025, 02:17 PM
      • cr4zychriss
        by cr4zychriss
        • Rebrand: PC Specialist
        11-14-2025, 04:04 PM
        by Vesko356
        08-11-2023, 03:27 AM
      • someonenotyou
        How to transfer information from one BIOS to another?
        by someonenotyou
        Hi.
        I am starting to learn about UEFI BIOS.
        At the moment I have Lenovo laptop with bad BIOS.
        I tried to clean ME region and transfer EC region from a known working BIOS, but the laptop does not POST (just fan spin).
        So there is something else bad.
        If I flash a know working BIOS, the laptop POSTs and boots into Windows.
        But the problem is, that the serial numbers, Windows key, and every thing else is from another laptop.
        Where do I start to transfer the S/N, Windows key and other information from one BIOS to another?
        Thank y...
        03-04-2025, 03:41 AM
