Need bios dell latitude 3410 plz
    Re: Need bios dell latitude 3410 plz
    Originally posted by volinakis View Post
    write only 8Mb chipset.
    Hi thanks man i really appreciate your time but with this bios the laptop doesn't turn on
      check soldering.
      all donations are welcome,
        check soldering.
        Thanks man now it's working fine. One of the pins were not soldered properly
          yep, it happens often. i usually redo the pads with soldering iron adding a little soldering paste.
            help me please. dell 3410 laptop
            lost bios password
            service tag DVWHQ93
            EX:30227196711
              lost bios password
              service tag DVWHQ93
              EX:30227196711
              https://www.badcaps.net/forum/showpo...42&postcount=4
              Become a Badcaps supporter
              Thanks to all supporters.
                lost bios password
                service tag DVWHQ93
                EX:30227196711
                flash only 8MB
                  Thank you, I hurried and tried to reflash it without removing the chip, now the laptop does not turn on, I sent it to a service center under warranty
                    Originally posted by SMDFlea View Post
                    Provide the full machine model number, serial number (or Service tag, SNID) and the board model number
                    brother my bios only late display plz clear
                    ST=F5WLF63
                      ST=F5WLF63
                      Try this than replay
                        Good morning, can you help me? The team doesn't give me an image.
                        here the original files
                        S/N: 5J9GD63 Latitude 3410
                          i need help no service tag after write bios
                          i cannot boot to OS and no bootable devices found
                            First of all you must write the SERVICE TAG in the description
                            Are you able to see hdd/ssd/nvme on First page ( Overview ) ?
                              maybe someone needed this. flash both. 16mb and 8mb. try and give feedback.
                                i did but nothing happen the service tag still blank after i changed save
                                thank you i try this file same with mine board
                                  Its working file i can add SN no thangzzzzzzzz👍😍😍😍
                                    Hello guys I have similar problem like someone before.
                                    On power keyboard flashes and no powering up - restarting and keyboard flashing (looping).
                                    D + Power -> LCD test mode works ok.
                                    I tried some bioses from this topic but the difference is that CPU fan blows for a second, and keyboard flash and restart (looping).
                                    Can you help ?
                                    DELL 3410
                                    MB: CML UMA 6L (19746-1)
                                    Service tag: 4FLBWZ2
                                      SMDFlea commented
                                      Editing a comment
                                      Post merged with 3410 thread.
                                    Ok, runned few more bioses, and checked under thermal cam - looks like PCH in CPU is dead - it just flashes and restart.
                                    Got bought other used motherboard same number but its admin password protected...
                                    Tried replacing ME region but failed. Can you guys help with password unlock?
                                    DELL 3410
                                    Service tag: 2XZQ763
                                      DELL 3410
                                      1st boot, press F2, write service tag, disable Absolute, save (Apply changes), restart. 2nd boot press Alt+F to exit manufacturing mode
                                        rex98 thans for bios, but before this one I tried flashing bios from my old board, and unfortunately new one started behave same like old one.
                                        Now when powering it up keyboard flashes (CPU and PCH seems to work for a second) and restarts - and its looping.
                                        Any idea if its possible to unbrick this? I tried to upload orginal bios but that not helped .
