acer nitro an515-43
  • genai
    • May 2015
    • 11
    • hungary
    Re: acer nitro an515-43
    I got new chip but the problem is the same.
    • genai
      • May 2015
      • 11
      • hungary
      I got the new chip, but the problem is a same.
      • dikmen
        • Apr 2015
        • 49
        • TURKIYE
        hi
        I need acer nitro an515-43
        Mb: fh50p la-h901p bios
        • hardware1
          • Sep 2021
          • 2944
          • N/A
          Originally posted by dikmen
          hi
          Upload your Original Bios and write your device Serial Number.
          all donations are welcome,
          • rridma
            • Oct 2018
            • sri lanka
            original bios and my Serial Number (same problem - no display)
            S/N: NHQBCAA001120088623400
            • hoaca388
              Badcaps
              • Jan 2022
              • 12140
              #26
              Wrong chip.
              ​https://www.badcaps.net/donate
              • Rokket
                • Jan 2024
                • Indonesia
                #27
                Hi guys i need some help if someone has a backup GPU bios for Nitro 5 AN515-43-R2NL ryzen 7 GTX 1650, thank you
                  Vesko356 commented
                  Editing a comment
                  You MUST:
                  • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                  • Provide a BIOS/EC dump if possible (vBIOS​ in your case)
                  • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
              • Rokket
                • Jan 2024
                • Indonesia
                #28
                Hi guys i need some help if someone have the same problem on Nitro 5 AN515-43-R2NL ryzen 7 GTX 1650, because my laptop turn on like 2 second and shutdown immediately.
                I allready backup the main and VBIOS IC BIOS and i dont know if its right/not
                SN:NHQ6ZSN0020210E6E3400
                • peste
                  • 13217
                  • ROMANIA
                  #29
                  look for a bios chip on the board, look at both sides... and post the content..
                  • lorins_core
                    BlackSmith
                    • Dec 2012
                    • 552
                    • Philippines
                    #30
                    hello to all Badcaps
                    I have an Acer Nitro (AN515-43) with no display Problem. fan spin then stop I did all possible basic solutions but still had the same problem. also, I test the voltage on always (5v,3.3v,1.8v) have I think need to flash bios may rebuild or repair the bios bin file,
                    here is the mobo prod. name FH50Q LA-J621P REV 1.0
                    and the flash file here
                      SMDFlea commented
                      Editing a comment
                      Thread merged.Please make use of the forum search before posting to find related threads where you can post your request.You do not need to start a new thread every time.
                      Read the rules, post the serial number/SNID https://www.badcaps.net/forum/troubl...before-posting
                  • alihomee
                    • Dec 2012
                    • 1580
                    • malaysia
                    #31
                    mobo code is:LA-J621P after 3 to 5 seconds notebook turns off....serial num is:NHQ6ZSM0010031057C3400.....i attached my orignal file
                    • kalilinux25
                      • Mar 2018
                      • 2089
                      • ZAMBOANGA SIBUGAY
                      #32
                      dmi Added
                      • alihomee
                        • Dec 2012
                        • 1580
                        • malaysia
                        #33
                        i am having same acer model:AN515-43-R3B4.....with serial num is: NHQ6ZSM001022164B73400....all supplies good but no display on screen...orignal file is attached
                        • shiyab
                          • Sep 2023
                          • 1543
                          • india
                          #34
                          hi try this file
                          • Zhyro217
                            • Jan 2025
                            • 8
                            • philippines
                            #35
                            need help guy's I have a Nitro AN515-34 (FH50Q LA-J621P Rev 1.0) Someone tried to replaced the lcd but the laptop died, I found out that the SIO was shorted. I replaced it and tried the bios and ec from post #5 but the laptop only gives me 1.025A with fun spin and turns off. I also tried different bios dumps but still the same issue. voltages are all present when the laptop turns ON, Anyone have other opinion on this issue?
                            • Zhyro217
                              • Jan 2025
                              • 8
                              • philippines
                              #36
                              This is my old dump incase it needs fixing ...
                            • TuxTaunk
                              • Oct 2022
                              • 16
                              • puerto varas
                              #37
                              hello guys, i have a same problem, this its my dump and serial its: NHQ6ZAL0091251928D3400. thanks! bpoard its a fh50q LA-j621p
