help unlock passbios unowhy Y13G010S4EI
    Re: help unlock passbios unowhy
    im trayng to unlock this bios lock but im not sur about this ?
    Y13G011S4EI EM_IG116_200B_ENE_F_V2.0
    Y13G010S4EI EM_IG116_200B_ENE_F_V2.0
      Re: help unlock passbios unowhy Y13G010S4EI
      there's no risk since you save the content of bios chipset. you can write it back and laptop should work as before.
      all donations are welcome,
        but there is a deference between this?
        and this my laptop here : Y13G011S4EI EM_IG116_200B_ENE_F_V2.0
        Last edited by SMDFlea; 10-15-2023, 09:40 AM. Reason: posted external images directly to badcaps
          [QUOTE=volinakis;1270528]
          Originally posted by Phil94 View Post
          Your bios dump is corrupted. Read it again and compare new dump against old saved dump.
          Dear Volikanis ,
          Here is the file.bin ,
          Could you help about this
          Unock password and communicate the new one ?
            [QUOTE=Phil94;1283198]
            Dear Volikanis ,
            try. you owe me a lamb
              [QUOTE=volinakis;1283219]
              Dear Volinaskis the lamb will wait,
              I don't know what to put for the bios password and finally access the machine
              Could you check , it seems the same original situation
                [QUOTE=Phil94;1288531]
                2 lambs, maybe 3rd time is a charm try Volinakis ...
                it should work, I erased all areas where passwords were. did you remove cmos battery before soldering bios?
                  [QUOTE=volinakis;1288534]
                  The issue is we don't have battery cmos on this motherboard , see the pictures below ,
                  Which advice do you have for me in this case ?
                    [QUOTE=Phil94;1289049]
                    Try this file and feedback
                      please unlock pass bios!
                        Post your dump and serial number and MB number here
                          Em-ig116-200b-ene-v1.0
                            Em-ig116-366b-v2.0
                              try this file than tell the result
                                no vga?
                                  [QUOTE=farouk_1994;1289054]
                                  No working ....
                                  Is normal we have a difference on Address of the eeprom (left colum) on your program compare me ?
                                  AMISETup (ASCII) is >> 22DB8C
                                  AMISETup (ASCII) is >> 22DB90
                                  I just searched on the flash that I did ans as you can see above it is quite empty on the friendsetup .... ?
                                  But when I start the unowhy and validate empty field , it's still ''invalid password ''
                                  Are there a 2nd password on the main menu of BIOS on this laptop ?
                                  Here is a copy of the BIOS , I think is the real model on my interface Xgpro with device T48
                                  What to do now ?
                                    Hello, can someone help me with a working bios for UNOWHY Y13G012S4EI - MODEL JUNE 2022 (Classe 2MRC1) SN: IFP223091322 EM-IG116-200B-ENE-TI-v1.0. I will attach the bios but it's corrupted . I tried multiples versions but with no luck. Thank you
                                      Hello
                                      help pleas unclock pass bios unowhy Y13G012S4EI
                                      impossible restaur windows because not admin
                                      I can no longer work with my pc
                                      thanks you very mutch
                                        hi please need unlock bios thanks
                                        N :IFP047056938
                                        MODEL:Y13G010S4EI
                                        motherboard EM IG116_366B_ENE_V2;0
