help unlock passbios unowhy Y13G010S4EI
    unowho Y13G011S4EI Bios Problem
    Hi, i have a laptop that has a bios password so i searched for bios bin files.
    when i tried some bin files the screen went black and the problem is that i didnt backup my original image. i tried all that i found here and others elsewhere with no luck. can anyone please provide me an image identical to mine even with a password is no problem. thanks
    Laptop Model: UNOWHY Y13G011S4EI
    Motherboard Model: EM_IG116_200B_ENE_F_V1.0
    Production date : Juin 2021
      Re: unowho Y13G011S4EI Bios Problem
      bad luck ...
      all donations are welcome,
        Try this and give feedback
          laptop wont turn on with that file. (no light, no cpu heat)
          with the others laptop turns on i see green light and feel cpu heat but the screen stays black.
            indicate a bios dump you used, I will try to clean TXE.
              Hi volinakis, those are three files that laptop turn on but without picture on screen that has the same name board name. pick any of them
              Thank a lot <3
                Thank a lot <3
                ok, try this one. I cleaned TXE Region from 1st bios dump.
                  Thanks a lot. muchas gracias amigo <3 <3
                    good to know it's working, for others wanting to use this bios is for Laptop Model: UNOWHY Y13G011S4EI
                    DMI data starting at 20FF0
                      Re: help unlock passbios unowhy Y13G010S4EI
                      PLEASE NEED UNLOCK THIS BIOS unowhy Y13G010S4EI 2021
                        I have a stupid question, but can someone explain to me how to install the bios bin file for my unowhy Y13. is it done with software, and if so how to bypass the administrator authorization to install it, because it is password protected or do you have to go through an external programmer. THANKS
                        I need also to know how to extract my bios bin file. Thanks
                          Yes, you have "to go through an external programmer", also you have to read the sticky threads first before asking more "stupid questions". All sticky threads.
                          Become a Badcaps supporter
                          Thanks to all supporters.​
                            Unowhy Y13 . I have to unplug the battery connector before flashing the bios. But I can't remove this connector and I pulled hard but it doesn't disconnect. I'm afraid to break it. Is there a special way to remove it? THANKS
                              that's ok . Thank you for your help
                                Originally posted by corona100 View Post
                                wrong chip this dump only 1 mb the original bios dump have 8mb
                                Dear corona100
                                I just finished extracting the file of the bios.bin , it is at 8195ko, here it is compress to 5116ko ,
                                Let me know if you can help me so delete or change this password ,
                                Tell me in this case what I should put in the case password
                                Let me know what you can do by thanking you in advance
                                  please unlock pass bios!
                                    Try
                                      Try
                                      Thank you very much !
                                        [QUOTE=Phil94;1214969]
                                        Hi ,
                                        Could you help me to unlock password of bios for unowhy_Y13 model : Y13G011S4EI ?
                                        motherboard is EM_IG116_200B_ENE_F_V1.0
                                        File.bin in attchment
                                        Which password could be associated ?
                                          can you help me for unowhy Y13G010S4EI no display
                                          thanks
