Re: Lenovo IdeaPad 3 15ADA05
@ bennardoelettronica yes bios post n.29
Blinking power button (but working laptop) is related to an empty DMI section?
Originally posted by Asphix View PostWhat happens if you don't edit the DMI with your laptop's data and directly flash the virgin trimmed ROM?
Don't have the serial number or Windows activation code in case of reinstallation of the operating system? Or could the laptop just not work?
Originally posted by bottoni View Postthanks to everyone, operation perfectly successful using the bios of post n.29, used Xhorse VVDI Programmer V5.3.1
Now I just need to find the bios of an Asus P2520s and an Acer E5-574g in .bin format
thanks
thanks
Originally posted by bottoni View Postwinbond 25Q64JWSIQ ?
I have done other tests but I can't solve it, even though I followed the guides posted the PC has the same problem, is there anything else I can try?
I will try to use it like the Xhorse VVDI Programmer V5.3.1 and I will update you
Thank you
Originally posted by bottoni View PostI'll try it since the latest version E8CN39WW was unsuccessful, perhaps corrupted... if you allow me, can you tell me which version it is?
thanks
my lenovo is: ideapad 3 15ada05 81w1, sn: pf2nmedc, mtm:81w1008hix
thanks
Originally posted by tracker1 View PostWorking bios Lenovo IdeaPad 3 15ADA05
GS450/GS550&GS750 NM-C821 Rev 1.0
thanks
Originally posted by SMDFlea View PostIf you have made a good bios backup already,then you have everything you need at posts 29 and 75
EDIT:
If I understand correctly, a file called "newbios.bin" is created and the old one becomes "newbios.bin.bak". I uploaded the created dump but still have the same problemLast edited by BennardoElettronica; 11-03-2023, 05:06 AM.
EDIT:
In fact, now that I think about it, the program did it, I'll try it now!
Originally posted by BennardoElettronica View PostHello everyone, I have a problem with my Lenovo IdeaPad 3. After a BIOS update from Windows when I turn on the PC it shows a black screen and the power LED flashes, I loaded a BIOS Dump on the BIOS CHIP and the power LED does not flash and stays solid with black screen. Which BIOS should I put to solve this? Here are the PC data:
IdeaPad 3 15ADA05
Model Name: 81W1
SN: PF2BK832
MTM: 81W1008DIX
Factory ID: JVHFC1
IdeaPad 3 15ADA05
Model Name: 81W1
SN: PF2BK832
MTM: 81W1008DIX
Factory ID: JVHFC1
Originally posted by haziko View PostPF28L5D7
ThanksAttached Files
