Originally posted by RiderXO
View Post
- use a 1.8 V adapter
- manually choose the most identical chip id as the EZP2019 wrongfully detected the bios chip as 93_EEPROM, ATMEL, AT93C46@16.
I went with SPI_FLASH, Winbond, W25Q128JV, (1.8v)
- double verification of reading bios with 3 Mhz setting as higher fx 12 Mhz did not produce the same data each time.
- Erase bios before writing then verifying bios data (Lesson Identified: if you only write - verify it's gonna produce an error).
ie. did you erase before writing ?
