I need bin bios acer aspire a315-56
  • shiyab
    • Sep 2023
    • 1592
    • india
    #41
    Originally posted by mtkapala
    Hello, can you please repair my bios file? The laptop starts but the screen is dark
    Acer A315-56-594W
    SN: NXA0TAA00503111B4F3400
    SNID: 03107252734
    MB FH5LI LA-J801P REV 1.0
    I tried these dumps but none of them work. On the original load the laptop draws 0.8A and jumps to 1A, and the ones from the forum still draw 0.7A
    hi try
    • mtkapala
      • Jul 2015
      • 24
      • Poland
      #42
      in my case there is a problem with KBC programming, I probably need to replace it first
      • mtkapala
        • Jul 2015
        • 24
        • Poland
        #43
        I replaced the KBC, and the new one allowed itself to be programmed, and the laptop booted up. Unfortunately, it only worked until the first restart. After that, it booted up with no display. When I tried to reprogram it using the EC dump from the forum, I have a problem. The memory doesn't pass verification, and the readout shows that the entire content is "ZZ." I can only erase the entire memory, and in this case, it passes verification. The whole dump becomes "FF," but the blank KBC doesn't program itself in this situation.
        Is there anything specific I need to do when reprogramming this KBC?
        • tano2060
          • May 2018
          • 28
          • Macedonia
          #44
          Originally posted by hoaca388
          Re: I need bin bios acer aspire a315
          Try my file :
          Or this file : ( suorce : https://forum.laboneinside.com/viewtopic.php?t=12280 )
          Second file works fine on:
          Acer Aspire 3 A315-56-327B
          MB: FH5LI LA-J801P REV 1.0
          Thanks.​
          • tcom1
            • Mar 2023
            • sri lanka
            #45
            Originally posted by BIOSSASI
            GREETINGS !
            ACER ASPIRE A315-56 FH5LI LA-J801P REV 1.0 STOCK BIOS DUMP
            If you have delay logo after flash bios , just simply clean flash this attached bios .
            No Passwords - Clean DUMP. Thank Me Later.
            Thanks Bro. Its work to me.
            • McAlister
              • Mar 2025
              • 4
              • Kazakhstan
              #46
              I have an Aser Aspire A315-56-53DR Model: N19C1 bios dump. Send or is there enough of them here?
              • peste
                • Dec 2016
                • 13451
                • ROMANIA
                #47
                post S/N, full name and model, motherboard model, ,etc.
                post the contents of the bios chip even if it is corrupted..
                • McAlister
                  • Mar 2025
                  • 4
                  • Kazakhstan
                  #48
                  Here it is backup BIOS for:
                  Aser Aspire 3
                  Model: N19C1
                  A315-56-53DR
                  S/N: NXHS5ER01211109E723400
                  SNID: 11104056234
                  Motherboard: FH5LI LA-J801P Rev 1.0​
                  Downloaded with black colored CH341A Programmer from notebook in good condition.
                  • kodinabeel
                    • Sep 2014
                    • 64
                    • saudi arabia
                    #49
                    PLS HELP ME FOR REMOVING PASSWORD..MODEL NO: a315-56-327T
                      SMDFlea commented
                      Editing a comment
                      post S/N Service Tag or SNID, full name and model, motherboard model etc.
                  • alexru1
                    • May 2025
                    • ru
                    #50
                    Hello. When you turn on the black screen.
                    Acer A315-56 LA-j801P FH5LI Rev 1.0
                    S/N : NXHS5ER00B1501234B3400
                    • doivaythoiem
                      • Jun 2024
                      • 124
                      • Việt Nam
                      #51
                      try
                      • gigasi
                        • Dec 2016
                        • 98
                        • Argentina
                        #52
                        Hi, I need the BIOS for my Acer N19c1 a315-56-32gy sn: NXHS61L00Y15016A3C3400
                        MB_FH5LI LA-J801P REV 1.0. I'm leaving the old BIOS on. It turns on, but the power LED turns off after a second. Thanks.
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12281
                          #53
                          Model Number: A315-56
                          Serial Number : NXHS6AL00Y15016A3C3400
                          • lecce1980
                            • Oct 2020
                            • 7
                            • Italia
                            #54
                            I have an Acer A315-56 notebook, s/n: NXHS5ET0040471F2993400, with motherboard FH5LI LA-J801P. After disconnecting the battery to replace the keyboard, it no longer boots. The blue LED turns on for a few seconds and then immediately turns off. I used the CH341A programmer to flash the BIOS, but without success. Does anyone have a working BIOS? Can someone tell me how to flash the EC.bin as well? Thank you.
                              • 21692
                              Thread merged. Post your original bios backup.
                              • lecce1980
                                • Oct 2020
                                • 7
                                • Italia
                                #56
                                the original file is no longer readable.
                              • lecce1980
                                • Oct 2020
                                • 7
                                • Italia
                                #57
                                "None of the BIOS files from the previous posts work on my PC. I found the original backup, or rather the one that was read from the original chip. I'm attaching it, thank you."
                                  • 21692
                                  The file is badly corrupted. Are you using a CH341A programmer and a clip ? .Did you erase the chip before programming the others
                                  • lecce1980
                                    • Oct 2020
                                    • 7
                                    • Italia
                                    #59
                                    "Yes, at first I used a clip, but later I desoldered the chip. For programming the chip, I used the CH341A. After saving the file (or rather, what was left of it), I erased and reprogrammed it with files found on the forum. Today, I made a backup of the KB9052 chip and reprogrammed it using the RT809H, but the issue remains: the blue LED turns on for a few seconds and then turns off. I'm attaching the original KB9052 file."
                                    • EbrahimSiami
                                      Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                                      by EbrahimSiami
                                      I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                                      **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                                      **What I have tried so far:**
                                      1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                                      07-02-2025, 02:31 PM
                                      ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                      This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-12-2024, 03:28 PM
                                      ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                      This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-12-2024, 02:30 PM
                                      ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                      This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                      ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                                      This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
