Lenovo E470 bios needed | CE470 NM-A821 Rev:3.0
  • novan.anjasuma
    • Jul 2023
    • 4
    • indonesia
    Re: Lenovo E470 bios needed | CE470 NM-A821 Rev:3.0
    everyone please.. i need CE470 NM-A821 REV 3.0 bios for my thinkpad (acpi bios error) thanks berfore..
    • shetos
      • Jul 2023
      • 6
      • egypt
      please i need unlock bios for lenove E470
      • vitecd
        • Aug 2023
        • 3
        • New Zealand
        Hi there
        I do have BIOS partially locked, don't know the password. Needed to turn on the virtualisation. Please, if possible.
        • volinakis
          • Jan 2021
          • 2875
          • N/A
          Originally posted by vitecd
          Hi there
          what means "partially locked"?
          Anyway, try this and follow steps described in "LENOVO BIOS AUTO-PATCHER" by Knucklegrumble (thanks go to him)
          [ HOW TO USE THE PATCH ]
          STEP 1: Flash and replace current BIOS with the generated patch file
          STEP 2: Boot the machine
          STEP 3: Press ENTER/F1/etc. to enter BIOS settings
          STEP 4: Enter any character when asked for Supervisor Password
          STEP 5: Press enter when it shows Hardware ID
          STEP 6: Press space bar 2x when asked
          STEP 7: Turn off machine
          STEP 8: Restore original BIOS
          STEP 9: Reset BIOS settings to factory default
          [ NOTES ]
          When booting the patched BIOS you might have to:
          - Hold the anti-tamper switch down the whole time (use tape)
          - Remove the hard disk or replace it with a locked one
          • vitecd
            • Aug 2023
            • 3
            • New Zealand
            I can change almost everything, just a few things not available.
            Thank you! I'll try and report
            • KLINIK ELEKTRONIK
              • May 2019
              • 51
              • indonesia
              #26
              HELLO
              i need bios THINKPAD E470C type 20H3
              SN :PF-0VL7XV
              CODE BOARD : CE470 NM-A821
              Problem, my bios working and display,but have warning INVALID RFID, MACHINE TYPE,SERIAL NUMBER,MACHINE UUID.
              i have try bios in this tread but no change
              I have uploaded bios original + bios ITE & VIDEO
              thank for help
              • Giffie
                • Nov 2023
                • 9
                • Malawi
                #27
                hello guys i need help with fixing my bios for Lenovo E470
                CE470 NM-A821 rev 2.0
                no display
                attached is the original bion file
              • novan.anjasuma
                • Jul 2023
                • 4
                • indonesia
                #28
                E470 Laptop (ThinkPad) - Type 20H1
                Nomor Seri
                PF0TCK3Z
                Mesin Tipe Model
                20H1S0AB00​
                ACPI BIOS ERROR
                please help me to fix it.. thanks
                • minhdigital
                  • Nov 2022
                  • 765
                  • Vietnam
                  #29
                  Nomor Seri
                  PF0TCK3Z
                  Mesin Tipe Model
                  20H1S0AB00​
                  ACPI BIOS ERROR
                  Send to you
                  • setiyo
                    • Mar 2018
                    • 36
                    • Indonesia
                    #30
                    Originally posted by mahmoodjavan
                    Re: Lenovo E470 NM-A821 REV 2.0 2016-08-25 No Display
                    thanks for your help
                    • zaido
                      • Sep 2017
                      • 20
                      • philippines
                      #31
                      please help remove the bios password
                      TYPE: 20H1-CT01WW
                      SN: PF-1357WH
                    • zaido
                      • Sep 2017
                      • 20
                      • philippines
                      #32
                      SMDFlea the available bios is No display on my laptop
                      • ronelex
                        • Oct 2016
                        • 195
                        • Philippines
                        #33
                        Anyone knows how to solve BSOD error during installation : ACPI BIOS ERROR for this model of laptop?
                        Lenovo E470C
                        SN : PF-0SNNJZ
                        TYPE : 20H3-A001CD
                        • ravenmx
                          • May 2018
                          • 180
                          • puebla
                          #34
                          please help to remove pw, i use patch but no works, the pw remains.
                          lenovo
                          nm-a821
                          p/n sl10l72617
                          • ravenmx
                            • May 2018
                            • 180
                            • puebla
                            #35
                            https://www.badcaps.net/forum/troubl...20#post1490620
                            Please help whith post #34
                          • yorossi
                            • Jul 2024
                            • 6
                            Hello all, I need your help. I have attached the original BIOS and the patched file that I created with the help of the autopatcher. However, after flashing the patched file, the laptop turns on and lets me select options to enter in the BIOS, but then the image turns black and nothing else happens. The laptop is not blocked, using CTR+ALT+Delete resets the laptop. Did I do something wrong? Can anyone help? Thank you in advance
                              • 22151
                              Type the laptop serial number, full name and model, motherboard model, etc.
                              read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                              • yorossi
                                • Jul 2024
                                • 6
                                The laptop model is a Lenovo Think Pad E470 , Type 20H1-006KGE S.n. : PF-0SH592. Mainboard model : CE470 NM-A821 REV 3.0.
                                Thank you.
                                • Avalan
                                  Lenovo E470 CE470 NM-A821 REV : 3.0 Bios needed
                                  by Avalan
                                  Hello, I require a bios for Lenovo E470, motherboard CE470 NM-A821, REV : 3.0. CPU - SR2ZU , GPU N16S-GTR-S-A2 , KBC - IT8586E.
                                  I've looked using Google and the forum but only found REV 2.0 motherboard bios with an unspecified GPU.
                                  Any help will be appreciated!
                                  08-27-2024, 04:05 PM
                                  Lenovo ThinkPad E470 Notebook E Specification for Upgrade or Repair
                                  This specification for the Lenovo ThinkPad E470 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E470 boardview and E470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                  09-06-2024, 08:20 AM
                                  09-06-2024, 08:05 AM
