Ms-16p51 ver 1.0 bios plz
  • mahmoodjavan
    Banned
    • Mar 2018
    • 584
    • iran
    Ms-16p51 ver 1.0
    backup
  • peste
    • 15686
    • ROMANIA
    Re: Ms-16p51 ver 1.0 bios plz
    Originally posted by mahmoodjavan
    Ms-16p51 ver 1.0
    backup
    post the full name and model of the laptop
    If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
    It only takes 1 minute:
    https://www.badcaps.net/settings/subscriptions
    • pooya_pm
      • Jan 2021
      • 265
      • iraq
      Ms-16p51 ver 1.0
      backup
      https://www.badcaps.net/forum/showth...light=MS-16P51
      • TopPop
        Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
        by TopPop
        Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
        I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
        12-14-2025, 09:40 PM
      • george94
        Gateway Laptop (gwtn141-10bl) won't post after enabling overclocking from bios
        by george94
        I have a laptop which i am trying to fix in which user enabled overclocking from bios and now it does not post.
        Laptop with battery only: when power button pressed, power led lights for 10 seconds then turns off
        Laptop with charger: white led in the charger and battery is charging, when power button pressed power led lights and it wont turn off
        With multimeter i checked and i found out that:
        EC chips gets 3.3 volts and it is not shorted (also no shorts on the board too)
        Cpu power rail is fluctuating between 0 and 300 milivolts when charger is connected
        01-27-2026, 02:42 PM
      • userbtcku
        I need a bios file for a Lenovo Thinkpad P1 Gen 3 laptop, model 20TJS2LA1B
        by userbtcku
        I need a bios file for a Lenovo Thinkpad P1 Gen 3 laptop, model 20TJS2LA1B.
        Can anyone help me find the BIOS file for this laptop?
        This laptop is having trouble booting from a flash drive or SSD.
        I've updated the BIOS with a file downloaded from lenovo.com, but it still doesn't work.
        So I'm thinking of flashing it another way.
        11-19-2025, 02:18 AM
      • legendkray
        BIOS Help Regarding GM5IX7A-GM6IX7A Origin Laptop
        by legendkray
        I have OriginPC EON 15SL, however, my laptop starts and shutsdown after 1-2 second. Keyboard leds are coming on then fans spinning then it shutsdown and not turning back on unless I plug out the power cable and plug it in. I had issues with bricked BIOS then I flashed BIOS I got from the vendor to the SPI chip and still it didn’t worked because my EC firmware was newer than the BIOS I have flashed. So I wanted to try flashing the EC chip with the correct firmware that matches with the BIOS also from the vendor and it worked everything was well, and then stupid me wanted to unlock some...
        07-05-2025, 09:25 AM
      • Betel_
        Gigabyte AORUS 7 9K Need bios laptop - Black Screen
        by Betel_
        I have a Gigabyte AORUS 7 9KF (2023), motherboard GA-X7E Rev 1.0, that is completely dead (no LED, no fans, no response to power button).
        History of the problem:
        • Original issue: failed BIOS flash attempt from Windows PE using the official Gigabyte update file
        • Chip was left completely blank (all 0xFF) after a bad flash
        • During first repair attempt, a PCB trace near the BIOS chip was damaged
        • A repair shop soldered the chip and reconstructed damaged traces with copper wire
        • Despite physical repair, board remains completely dead
        BIOS firmware...
        07-18-2026, 01:31 PM
