Need unlock HP elitebook 830 G6
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    #181
    Re: Need unlock HP elitebook 830 G6
    Originally posted by bilel
    hi please can you unlock file bios and thank you
    Here you are
    Become a Badcaps supporter
    Thanks to all supporters.​
    • philipgwen
      • Jun 2021
      • 13
      • Ghana
      #182
      hp Elitebook 830 g6 cataloni 6050A3022401-mb-A01-(A1)
      please i need hp elitebook 830 G6 bios bin file with S/N 5CG014D3BB.
      i mistakenly did not save the one i extracted.
      i have attached images of the motherboard
      • dvt1989
        • Jan 2020
        • 41
        • Viet Nam
        #183
        There is a source without a picture, thanks for the help of ad build
        • bilal767
          • Feb 2023
          • 43
          #184
          I have HP 830 G6 with bios locked S/N: 5CG9381HLW. I have tried HPunlocker, after writing the file that i got from Hpunlocker the laptop has no display. The caps lock light stays on solid white and flashes once and goes solid again. I have attached the locked bios dump file. Could anyone help please.
          Thanks in advance.
          • Expired
            • Feb 2023
            • 34
            Thanks in advance.
            try and reply with results
            • bilal767
              • Feb 2023
              • 43
              #186
              Thanks for your quick response. First it was not showing any display after writing this fie. It kept restarting itself with no display making me think that the file has not worked. but after about 4/5 restarts, it eventually showed the display and now its working fine.
              Many Thanks for your help!
              • bilal767
                • Feb 2023
                • 43
                #187
                Although the laptop has turned on after writing your file but the bios password is still there.
                • Expired
                  • Feb 2023
                  • 34
                  Is there another bios chip that is 16mb?
                  • bilal767
                    • Feb 2023
                    • 43
                    #189
                    No there is just one with 32mb. For sure there isn't any on top side. Could the other be the other side of the board? Thanks
                      • 21971
                      Thanks in advance.
                      You didn`t make a good backup it is only 139.5 KB compressed,it should be around the same size as the others posted in this thread, over 10MB
                      There should be, read some previous posts in the thread.
                      • bilal767
                        • Feb 2023
                        • 43
                        #191
                        When I extract the BIN file from bios, shows 32MB but after compressing it becomes 139kb compressed. Could you please suggest any solution to this please. I have tried few times with different software.
                          • 21971
                          That depends on a few things. What is the the programmer model and software version.
                          Are you:
                          Desoldering the chip and using an adapter board
                          Trying to read a WSON8 chip with a SOP8 clip
                          Trying to read a WSON8 chip with a WSON pogo test probe
                          Here`s a bit of additional reading -> How to dump and flash https://www.badcaps.net/forum/showpo...40&postcount=2
                          • bilal767
                            • Feb 2023
                            • 43
                            #193
                            Are you:
                            I am using NeoProgrammer 2.2.0.8 with CH341A
                            And trying to read with WSON pogo test probe
                              • 21971
                              There is a newer NeoProgrammer version but i doubt thats the problem, its the pogo probes,they`re unreliable.
                              • testingceshi123
                                • Sep 2023
                                • 5
                                • Malaysia
                                #195
                                anyone can help to unlock this bios password
                                  • 21971
                                  You must provide the serial number https://www.badcaps.net/forum/showthread.php?t=103570
                                  • Expired
                                    • Feb 2023
                                    • 34
                                    have you tried using RCUnlocker?
                                    • jatoi
                                      • Jan 2015
                                      • 83
                                      • pakistan
                                      #198
                                      please unlock this bios
                                        • 21971
                                        You MUST:
                                        • Expired
                                          • Feb 2023
                                          • 34
                                          Code:
                                          After entering BIOS, go to security tab and reset security settings to default!
                                          Security errors are expected once or twice on first boots.
                                          Try and reply with results.
