HP Probook 450 G5 and TL866II not work
  • Drakgon
    • Nov 2020
    • 23
    • Czech Republic
    Hallo, I have a problem with read the BIOS HP ProBook 450 G5 (motherboard: DA0X8CMB6E0 Rev: E). I buy TL866II with SOIC8 clip and when i use "25 Flash detect" Xgpro detect GD25B128C or GD25Q127C witch Device ID: C8 40 18 and if I use "READ" show "Check ID Error!", Check ID is: C0 00 08. On chip is text GD25B127DSIG. I don't see this model in Xgpro. Can I solve this problem? Thank you for any help.
    I'm sorry if I placed it to wrong thread.
  • Drakgon
    • Nov 2020
    • 23
    • Czech Republic
    • Drakgon
      • Nov 2020
      • 23
      • Czech Republic
      Re: pls Bios HP Probook 450 G5
      Than problem is with use SOIC8 clip. If I desoldering the chip - Device ID is OK. But - I try read and erase chip with uncheck "Check ID". But at write *.bin back to chip get any error. If I read bad data, I don´t have a correct bios - where I can find *.bin with work BIOS for HP ProBook 450 G5 (motherboard: DA0X8CMB6E0 Rev: E)? Thank you very much
      • Drakgon
        • Nov 2020
        • 23
        • Czech Republic
        Re: HP Probook 450 G5 and TL866II not work
        • LenBios
          • 122
          • Ker
          just plug the AC Apadter
          • Drakgon
            • Nov 2020
            • 23
            • Czech Republic
            But I click erase with clip and bad Check ID. Did I damage the data? Or if I write data with bad Device ID so nothing was written? If I damage data - can I write some other bios from this forum?
            • qayyum786
              • Aug 2018
              • 1933
              • INDIA
              try this bios and
              try with new bios chip with given bios chip number
              (Winbond W25Q128)
              (GigaDevice GD25x128)
              (Macronix MX25L128)
              • Drakgon
                • Nov 2020
                • 23
                • Czech Republic
                Originally posted by qayyum786
                try this bios and
                (Winbond W25Q128)
                (Macronix MX25L128)
                Thank you! I can try it.
                But must I write new bios or is chance that I did not damage the data on my chip? I think that must be damage when I erase and write with bad Device ID. Reportedly, it was enough plug AC adapter.
                Now I have my chip unsoldered and connect is OK.
                  • 21040
                  both your threads have been merged into one,and moved to the "Bios Requests" section.
                    • 21040
                    try this bios and
                    (Winbond W25Q128)
                    (Macronix MX25L128)
                    The exact same bios here,post #7 https://www.badcaps.net/forum/showthread.php?p=942171
                    • Drakgon
                      • Nov 2020
                      • 23
                      • Czech Republic
                      Originally posted by SMDFlea
                      But this is for HP Probook 470 G5... I have 450 G5...Is not problem?
                      • qayyum786
                        • Aug 2018
                        • 1933
                        • INDIA
                        Do you have a backup dump
                        • Drakgon
                          • Nov 2020
                          • 23
                          • Czech Republic
                          No... I try dump it by clip first, but it no work correctly and I erase and write bin with error... Now I have desoldering chip and comunication with XGecu is OK, but I don´t have any bios... Now I need complet *.bin for my HP ProBook 450 G5 (motherboard: DA0X8CMB6E0 Rev: E
                          • qayyum786
                            • Aug 2018
                            • 1933
                            • INDIA
                            Give me laptop serial number
                            • Drakgon
                              • Nov 2020
                              • 23
                              • Czech Republic
                              Part number: 4WU82ES
                              Serial number: 5CD851298F
                              • qayyum786
                                • Aug 2018
                                • 1933
                                • INDIA
                                Originally posted by drakgon
                                part number: 4wu82es
                                serial number: 5cd851298f
                                try anyone 1 is clean me & 1 is new builded
                                • Drakgon
                                  • Nov 2020
                                  • 23
                                  • Czech Republic
                                  try
                                  I´m at home now. I try it in the morning and send you info. Thank you and have a nice day
                                  • Drakgon
                                    • Nov 2020
                                    • 23
                                    • Czech Republic
                                    I try first one and notebook cannot be turned on... Only flashing orange LED at the DC connector.
                                    • qayyum786
                                      • Aug 2018
                                      • 1933
                                      • INDIA
                                      try second one new builded
                                      • babyboo092
                                        babyboo092 commented
                                        Editing a comment
                                        did it work when he tried the second one?
                                      HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                      This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                      09-07-2024, 07:12 AM
                                      09-07-2024, 06:40 AM
                                      HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                      This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                      09-07-2024, 05:50 AM
                                      HP ProBook Prenosni računalnik ProBook 445R G6 Notebook 400 Specification for Upgrade or Repair
                                      This specification for the HP ProBook Prenosni računalnik ProBook 445R G6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Prenosni računalnik ProBook 445R G6 boardview and Prenosni računalnik ProBook 445R G6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                      09-06-2024, 10:51 AM
