820-4924 please help
  • messengertr
    • Mar 2024
    • 7
    • Turkey
    2013 A1502
    EMC 2678
    board model number 820-3536-A
    • peste
      • 13335
      • ROMANIA
      Originally posted by messengertr
      2013 A1502
      EMC 2678
      try..
      • messengertr
        • Mar 2024
        • 7
        • Turkey
        Thank you, I will try it tomorrow and let you know
        • Barttech Computers
          • Dec 2024
          • 27
          • Usa
          Hi guys trying to help a customer thats trying to revive an old Macbook its got a defunkt Icloud on theres so I read the Rom and cleared $svs region out and replaced with FF but now only a black screen, completely wierd?. I have attached the original dump and the dump I cleared, can anyone assit please, now occasional chime and black screen, have tried another bios chip of a donor and it work but obviously wrong serial and bad me region made it super slow,
          Any help appreciated
          • peste
            peste commented
            Editing a comment
            post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
          • Dec 2024
          • 27
          • Usa
          BOARD ID IS 820-4924
          • peste
            • 13335
            • ROMANIA
            #26
            post S/N, full name and model, motherboard model,EMCetc.
            read the forum rules..
            https://www.badcaps.net/forum/troubl...ore-posting​
              • Dec 2024
              • 27
              • Usa
              #27
              It was in title, serial number isn't needing to be changed, original bios has SSN in hex, you moved my thread to a thread with late 2013 a1502 mine is mid 2015 emc 2835 board id 820-4924 as title suggested.
                SMDFlea commented
                Editing a comment
                Posts moved to 820-4924 topic.
            • peste
              • 13335
              • ROMANIA
              #28
              try..
              • thesame
                Samsung UE40F6670SS messed tcon type in service mode.
                by thesame
                Hy guys i have this Samsung Tv model UE40F6670SS and i have messed with the service menu and selected the wrong tcon type .Is there a way to reset the service menu to defaults or how can i find the right tcon type since i didnt took a picture or remember the original setting?
                Since i have selected the wrong tcon type the colors are a bit strange and sometimes the backlight it looks like its auto adjusting... ...
                11-22-2023, 03:04 PM
              • Geeker007
                Friend messed up my laptop motherboard while working on my bench
                by Geeker007
                Hi All,
                So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
                So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
                I have not tried putting...
                06-16-2025, 01:40 PM
              • modd1uk
                Dell 5420 - First timer, messed it up, need help please.
                by modd1uk
                Hi guys
                Its my own fault, I'm just hoping somebody can help and the laptop isn't bricked.
                The BIOS chip is a 25rh256cxiq, I read it using neoprogrammer 2.2.0.10 but like a complete idiot didn't search the chip, it was set to the wrong chip, I read the BIOS, unlocked it, flashed the unlocked file and now the laptop is dead, won't even try to power on, only after I'd flashed it I realised the wrong chip was selected.
                How stuffed am I? Is there a way to flash a generic Dell Latitude 5420 BIOS so I'm not stuck with a dead paper weight?
                I have another...
                03-22-2025, 03:24 PM
              • Ovanes SMD
                HP Envy 13-BF0013DX Laptop Motherboard Intel® Core™ i7-1250U CPU 8GB N15665-001 I messed up bad
                by Ovanes SMD
                Can someone tell me how i can locate and what is the most cheapest way to find this voltage regulator. College student. discovered repairs and fell in love with it. I connected a 12 volt motor to my 5volt usb port and the motherboard stopped working charging no lights nothing. I took it apart, good at doing that bad at putting it back together"joke" sortve.
                I attached a picture please if someone can tell me what that part is and how i can get it i have a soldering and air gun. Not in a rush. The reason why i need to change this is because i accidently disconnected the battery while...
                08-24-2024, 07:04 PM
              • Endlessmist
                Surface Pro 4 - need help with some messed up components
                by Endlessmist
                Hi everyone
                Here is the case that i'm trying to solve.
                (short intro to explain what happened)
                I bought second hand Surface Pro 4 and when I tried to reinstall the Windows it appeared there was the password on UEFI. Seller don't reply anymore. I decided to reflash the UEFI chip to remove the password. So I need to remove the chip from the motherboard first.
                I have basic experience of repair tablets and phones, like battery or display change. So i opened the Surface Pro 4 and removed the motherboard successfully.
                (the...
                04-22-2023, 07:30 AM
