toshiba protege Z30-b bios
  • Sabra
    • Feb 2020
    • 7
    • sanaa
    portege z30-b need plz
  • bachir2004
    • Feb 2015
    • 439
    • maroc
    toshiba protege Z30-b-16m
    can someone please help me to decompress this bios update(bin file)?
    • evserv
      • Jun 2014
      • 363
      • Russia
      Re: toshiba protege Z30-b-16m
      https://github.com/LongSoft/ToshibaC...eases/tag/v0.1
      • qayyum786
        • Aug 2018
        • 1959
        • INDIA
        send me your backup dump i want to match what i got it from exe file
        • qayyum786
          • Aug 2018
          • 1959
          • INDIA
          i have try many time previously but no successes
          can you explain please how to use ToshibaComExtractor
            • 22159
            First you have to run the toshiba bios exe, it will start extracting to C:\ProgramData\Toshiba\BIOS_Package, (if you can`t see the folder change folder options to "Show hidden files and folders") it will delete the contents of the BIOS_Package folder itself after a message pops up saying this computer is not supported .When it starts extrating quickly copy the contents to another folder ,i have a folder called "BIOS_Package - Copy" ,as soon as the "BIOS_Package" foldder is created i drag the folder over the "BIOS_Package - Copy" folder and quickly press the enter button on the keyboard when the message about copying appears. If you do it all quickly enough you`ll have the extracted contents in the copy folder, including the COM file with a name similar to BIO00A0T.COM .Run comextract from the command line: comextract.exe BIO00A0T.COM biosupdate.bin
            Thats just how i do it,i`m sure there`s other ways like making folders read-only or some other methods.
            EDIT: there another way to extract the exe with the /ext switch ,although it doesn`t work with every bios P0096v650_ECBFv140.exe /ext
            • bachir2004
              • Feb 2015
              • 439
              • maroc
              many hanks it works but i am really stuck.please i need help to make a clean firmware.
              • qayyum786
                • Aug 2018
                • 1959
                • INDIA
                Originally posted by SMDFlea
                First you have to run the toshiba bios exe, it will start extracting to C:\ProgramData\Toshiba\BIOS_Package,it will delete the contents of the folder itself after a message pops up saying this computer is not supported .When it starts extrating quickly copy the contents to another folder ,i have a folder called "BIOS_Package - Copy" ,as soon as the "BIOS_Package" foldder is created i drag the folder over the "BIOS_Package - Copy" folder and quickly press the enter button on the keyboard when the message about copying appears. If you do it all quickly enough you`ll have the extracted contents in the copy folder, including the COM file with a name similar to BIO00A0T.COM .Run comextract from the command line: comextract.exe BIO00A0T.COM biosupdate.bin
                Thanks for your kind information
                • qayyum786
                  • Aug 2018
                  • 1959
                  • INDIA
                  size mismatch with your bios regioneven i remove access above given FF FF ofset maby you have downloaded wrog exe file from Toshiba support site
                  let the master SMDfela come than he can help to solve the mystery
                    • 22159
                    Try this one .
                    Post #5 edited: there is an easier way to extract the exe with the /ext switch - P0096v650_ECBFv140.exe /ext
                    • bachir2004
                      • Feb 2015
                      • 439
                      • maroc
                      thank you so much SMDFlea your dump worked but there is still a problem,see the attached picture.pc returned to costumer.
                      • its service
                        • Feb 2021
                        • 148
                        • india
                        Re: toshiba protege Z30-b bios
                        thoshiba PROTAGE Z30-B P/N : PT251U-061010F1
                        bios password
                          • 22159
                          bios password
                          https://www.badcaps.net/forum/showpo...42&postcount=4
                          • its service
                            • Feb 2021
                            • 148
                            • india
                            only supervisor - registerted locked
                              • 22159
                              can u plz unlock this bios password
                              No.
                              3.10. Toshiba
                              3.10.1. Consumer
                              A lot of Toshiba consumer laptops have a jumper on the motherboard that needs to be shorted before boot to clear the password.
                              3.10.2. Business
                              Most Toshiba business laptops do not have a jumper, and the password is stored inside a protected region of the EC. See affected models: https://www.badcaps.net/forum/showpo...2&postcount=19
                              Either you need a donor EC without password, or you need to unlock through challenge-response.
                              Response generator is not available publicly, however, some generous people may be able to generate a response for you. Ask in this thread: https://www.badcaps.net/forum/showthread.php?t=79489
                              Laptop must not be rebooted, the challenge will change.
                              • its service
                                • Feb 2021
                                • 148
                                • india
                                sir can please check the image sir ill attached image plz check
                                  Toshiba Portege Portege Z30-C-1CV Notebook Specification for Upgrade or Repair
                                  This specification for the Toshiba Portege Portege Z30-C-1CV Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Portege Z30-C-1CV boardview and Portege Z30-C-1CV schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-06-2024, 05:33 AM
                                  Toshiba Portege Portege X30-D-10V Notebook Specification for Upgrade or Repair
                                  This specification for the Toshiba Portege Portege X30-D-10V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Portege X30-D-10V boardview and Portege X30-D-10V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-06-2024, 05:40 AM
                                  Toshiba Portege Portege X20W-D-11N Hybrid (2-in-1) Specification for Upgrade or Repair
                                  This specification for the Toshiba Portege Portege X20W-D-11N Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Portege X20W-D-11N boardview and Portege X20W-D-11N schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
