Need Clean Bios for DELL Vostro 5471
  • BeHeX
    • Aug 2022
    • 8
    • Polska
    Re: Need Clean Bios for DELL Vostro 5471
    Originally posted by hoaca388
    Vostro 5471
    Service Tag: 8F74C02
    thanks but unfortunately in this bios the fans are on full again, the keyboard is backlit but nothing else is happening .. could it be some other reason than a faulty bios?
    • hoaca388
      Badcaps
      • Jan 2022
      • 12441
      Maybe,using a external monitor if not have display, check other reasons
      • BeHeX
        • Aug 2022
        • 8
        • Polska
        I tried on other monitors, etc. and still the same, I don't know what to do now
        • hoaca388
          Badcaps
          • Jan 2022
          • 12441
          Post your problem here : https://www.badcaps.net/forum/forumdisplay.php?f=23
          • SharkeyJoe
            • Jul 2022
            • 6
            SMDflea known-good dump managed to revive a dead 5471, but it now thinks it's an inspiron 5370. Both models use the same mobo but firmware images seem have different options in intel FIT re Intel PTT (at least, maybe others). So, the laptop's dTPM isn't seen by windows.
            I recommend you try one of the cleaned 5471 dumps first, if you have a 5471.
            • SharkeyJoe
              • Jul 2022
              • 6
              I've confirmed that the TPM issues I had were due to using the bios Image from #10
              SHA256: 35f0a68f4b524fdc4f3c5ba9cc1aa2d3c4dc8be548dea0361f9387519b47431f
              In FIT, this image had "Enable fTPM at startup" ON, unlike my original Bios and the image in #2. As a result, after flashing my vostro 5471 booted, but I had no functioning TPM (bitlocker was suspended by the OS and could not be resumed).
              I flashed the bios image from `new5471_CLEAR_ME.rar `, provided by Ghamidi in #2,
              SHA256: 962d3ac8f13e68027267eba26dc167e98b54cce85983dad4eafececade9dadb9
              Bios Version: 1.14
              Service Tag: 1THS902
              and the discrete TPM is working again.
              Depending on your model (Maybe Inspiron 5370 has only fTPM/PTT???), you may want either. But for Vostro 5471, the one from #2 worked for me.
              Thank you.
                • 22285
                Thanks for the info
                • SharkeyJoe
                  • Jul 2022
                  • 6
                  Additional information for debugging Vostro 5471 flash issues,
                  hopefully useful to someone someday:
                  Symptom: No charger light, power button LED on, but computer doesn't boot
                  Problem: flash chip not present/soldered properly/dead.
                  The EC bootloader can't read its firmware from flash, so the laptop doesn't boot at all.
                  Symptom: No display. Diagnostic Led 2 Amber+1 white, described in manual as "Processor problem".
                  Problem: EC started, but flash is corrupted, Boot guard or ME issues. Reflash Bios.
                  Symptom: No display, fans on full speed, no diagnostic code.
                  Problem: I had this after flash was corrupted, but only after I disconnected CMOS battery.
                  Apparently, some setting were lost and this caused a different state. Bios Reflash solved it in my case.
                  Other LED diagnostic codes are less ambiguous, pay special attention to memory issues
                  due to badly seated RAM stick. Very common.
                  On a working machine, you can check which TPM you have from powershell with the `Get-TPM` cmdlet. For my Vostro 5471's discrete TPM chip the vendor string is "NTC", from the Nuvoton chip.
                  If the vendor string is "INTC" (INTel Corporation), it means the system sees/expects a PTT/fTPM.
                  • SharkeyJoe
                    • Jul 2022
                    • 6
                    I was able to confirm this using the schematics. Inspiron 5370 was known by the internal product name "LOKI", and does not have a discrete TPM (So use SMDFlea's image from #10). Vostro 5471 was known as "ARMANI" and have a discrete TPM (So use the image in #2, like I did).
                    After flashing #2 image, HWiNFO64 still shows the laptop model as "Inspiron 5370". I don't know if that's a glitch, or if all models in this family generically show up with that name. But so far, I haven't encountered any odd behavior or issues.
                    • yukselen
                      yukselen
                      • Jun 2021
                      • 43
                      • türkiye
                      #30
                      Try this one .
                      THANK YOU IT WORKS VERY NICELY
                      • yukselen
                        yukselen
                        • Jun 2021
                        • 43
                        • türkiye
                        #31
                        DELL VOSTRO 5471
                        SN..BJ74C02
                        THERE IS NO IMAGE. PLEASE CORRECT IT.
                        • yukselen
                          yukselen
                          • Jun 2021
                          • 43
                          • türkiye
                          #32
                          Originally posted by yukselen
                          DELL VOSTRO 5471
                          SN..BJ74C02
                          Could you please help me?
                          • yukselen
                            yukselen
                            • Jun 2021
                            • 43
                            • türkiye
                            #33
                            DELL VOSTRO 5471
                            SN..BJ74C02
                            HELLO,
                            WHEN I WRITE ANOTHER BIOS, BITLOCKER DOES NOT WORK. TPM DOES NOT WORK. CAN YOU FIX THE BIOS?
                            PLEASE
                              DELL Vostro 5471 Notebook 5000 Specification for Upgrade or Repair
                              This specification for the DELL Vostro 5471 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5471 boardview and 5471 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro 5471 Notebook...
                              09-06-2024, 02:30 PM
                              09-06-2024, 08:01 AM
