Dell Latitude 5410 Bios Password 8FC8
    Re: Dell Latitude 5410 Bios Password 8FC8
    Originally posted by lapfix View Post
    Try and give feedback
    1st boot, press F2, write service tag, disable Absolute, save, restart. 2nd boot press Alt+F to exit manufacturing mode.
    Thank you very much, you helped me a lot, in a very difficult time
      hello, could I ask to unlock my bios? Thank you very much.
        Originally posted by drobino View Post
        hello, could i ask to unlock my bios? Thank you very much.
        feedback
          Thank you very much. It works perfect.
            hello does clean me makes the password clear?
              No ,and NO https://www.badcaps.net/forum/showpo...&postcount=263
                Hello. After dump my bios chip (qh256bxiq) on dell 5410 with neoprogrammer and ch341a, i have an error on UEFITool : "UEFI volumes not found".
                Have you some workaround or solution?
                In attachment my dump file
                thanks for your help
                  If someone could help me... I didn't found solution for now
                    This file not good, try to read it again correctly or use a good SPI Programmer which can deal with your Chip.
                    all donations are welcome,
                      Thanks for your feedback. I will try to make a new dump. To you know if there is any pb with ch341a dongle with this kind of chip?
                      Il not, i will try to connect better the chip to the dongle (i use wson8 clip)
                        Hello
                        I've made new dump and now it seems good (i could open it with UEFItool)
                        however where can i found original bios (unlock) to make the manipulation (copy/paste region)? On dell website i only found the exe file without the bin file
                        in attachment the dump of my locked dump
                        Many thanks
                          For extraction bios image from dell exe :
                          https://www.badcaps.net/forum/showpo...95&postcount=6
                          What region you want to copy/paste !!
                            Thanks for the link
                            I have understand that from the "locked bios", i have to use an unlock bios and replace the "ME region" from the locked dump to the unlock dump.
                            Is it ok? (or i've made mistake)?
                            With the extractor, i have a lot of file (and not only 1 bin file)... I will try to understand but i'm quite newbie if you have information, it will be good...
                              Thanks for the link
                              No , you make mistake
                                ok. I've send you a MP if you could help me
                                  Hello
                                  Many thanks
                                  Here's your Unlocked Bios, hope it works fine.
                                    Originally posted by andrew25 View Post
                                    did you solve it... i have same problem
                                    Try this clear ME and pass.
                                      thanks a lot, it works.
                                        Hi all I need a Help with pass 5410 32mb
