Microsoft Surface Pro 7 NEED BIOS. HELP!
  • mops
    replied
    Originally posted by volinakis
    try this one
    Tried.... same behaviour - windows logo for about 3~4 seconds, then switches off :/
  • volinakis
    replied
    Originally posted by vetal3vetal4687
    Thank you! All settings are saved, no password.
    you are welcome
  • vetal3vetal4687
    replied
    try
  • volinakis
    replied
    Good day! Please help me remove the password in the bios dump.
    Surface Pro 7 (1866) i5 / 8 / 128
    Serial number 024762704553
    try
  • vetal3vetal4687
    replied
  • peste
    commented on 's reply
    here only "bios requests"...if you have another problem, move the discussion to the main forum...
  • khayal9
    replied
    Microsoft Surface Pro 7 BIOS 1866 128GB 021775602353 anakart modeli JALAMA_ICL_MB DV:2 0B
    SLP_S4# no signal 0v please help where is the problem?
  • Behindikus
    replied
    Originally posted by minhdigital
    Send to you, try
    Thanks a lot, but its still the same behavior. I think i have to order a new bios Chip.. my ch340 recognized it as a JQ Chip not as a JW. Something seems to be wrong...
  • khayal9
    replied
    I found a bios from the forum, the computer turned on before but the touch screen was not working and the SSD was not visible, I tried different bios, all of them failed, now even if I write the bios that worked before, it stays at the logo, I tried with new EPROMs, still failed, the Windows logo appears for 3-4 seconds.
    Can someone tell me how the image comes to the motherboard without the bios chip? I think the problem is not the bios, there is something different
    Please help
  • minhdigital
    replied
    Originally posted by Behindikus
    I tried some BIOS files from this Forum but i am still at the flashing Windows Logo. At First IT was visible for about a second, now i See the Logo for about 3 Seconds. Seems Like Something changed.
    But i still need Help
    Send to you, try
  • Behindikus
    replied
    Hi!
    I inherited a Surface 7 Pro (1866) from my Father in law and it's bricked.
    Keeps rebooting / flashing Logo.
    The Serial is 028134302953
    If its possible we need a fresh bios without Passwords.
    Thank's a lot!
  • volinakis
    replied
    Originally posted by mops
    This is the original bios. I must read the serial number of a different tablet frame. I have several of them (sp7's, also sp5's and sp4's)
    try this one
  • mops
    replied
    are you sure this is original bios? Because it has other serial. (071473602453)
  • volinakis
    replied
    Hello.
    I also need a BIOS cleaned/rebuilt for Surface 7 pro i5/8/256 serial# 067245401453
    This device is flashing windows logo for about 2 seconds then shuts off.
    I have tried the guide for cleaning BIOS, but I ran into issues.
    1. Using CMSE 13.3r7, decomposed BIOS does not have "ME Region.bin" file. There's file "ME Sub Partition.bin" (3.3MB). I assume this is the same, but differently named.
    2. I downloaded surface pro 7 firmware and drivers from MS and there's file there "SurfaceME_13.0.2436.2.bin" (4MB). I assume this is the 'clean' ME file. it is NOT the same version as the file in original bios. I was not able to find the same version.
    3. When I swap the original file with the MS one and try to load CSME project I get "error 209: Failed to get image metadata sub partition"
    4. So I tried decomposing, swapping the file and building bios (without exiting fit.exe), and it built a bios file. I compared original with this one using hex editor and I can see that there's block that is different, so I assume the swap was succesfull.
    5. resoldered the bios. Now the machine stays on windows logo for about 3~4 seconds, then shuts down. cant get into the bios.
    Attached bios is the original as it came from faulty machine.
  • mops
    replied
    Hello.
  • khayal9
    replied
    Originally posted by peste
    post S/N, full name and model, motherboard model, etc.
    Hello, thank you for your answer and help. Microsoft Surface Pro 7 BIOS 1866 128GB 021775602353 motherboard model JALAMA_ICL_MB DV:2 0B
  • peste
    replied
    Originally posted by khayal9
    Microsoft Surface 7 1866 128 GB 021775602353 The computer was working when it came to me but it had a bios password. When I removed the bios chip, the chip was damaged. I bought a bios chip with the same code. I tried many bios from forums. They all shut down 2-3 seconds after the windows logo. I found a suitable bios. The touchscreen didn't work on it and there was a problem with not seeing the ssd. I started looking for a different bios. Later, even though I wrote the bios that worked, it still doesn't work. It shuts down 2-3 seconds after the windows logo. I think the bios chip is damaged.
    And I have a question in my mind. Even when the bios eprom is removed from this computer, an image appears on the screen. How does this happen?
    Is there anyone who can help me?​
  • khayal9
    replied
  • Behindikus
    replied
    Hi!
    Thank's a lot!
    Is anybody able to help? We hope that we find a way to recover the lost pictures and memorys.
  • Behindikus
    replied
    Hi!
    Thank's a lot!
