Lenovo ideapad s540-13api (AMD) driver dump request
  • NonaHarry
    • Sep 2020
    • 4
    • Hungary
    Hi everybody
    I have a ideapad s540-13 AMD version and the bios is broken during the update process. I tried to use Phoenix Crisis Disk to reflash it but with no luck.
    So I bought a bios programmer (CH341A) and SOP8 clip. Right now I need to extract bios file from the executable.
    What I have tried:
    Double click the EXE. I got a "ERROR 255 - TDK library initialization failed" error and nothing appeared in %temp% folder.
    Extract the EXE with 7z. It can not open it.
    I did find some file in the temp folder from laptop hard drive. I will attach them as well.
    Also I found two SOP8 chips on the board. Winbond 25Q80DVSIG and GigaDevice 25LB64CSIG which one is the bios chip?
    So appreciative of your help.
    Cheers
    • 20914
    Re: Lenovo ideapad s540-13api (AMD) driver dump request
    Check this tutorial to extract a TDK bios https://www.badcaps.net/forum/showthread.php?t=80861 . The bios will be the 25LB64CSIG. You`ll need it as it will have your DMI info, serial etc .Post your bios backup .
    • NonaHarry
      • Sep 2020
      • 4
      • Hungary
      Thanks man, that works! The capsule is the same as I found in the laptop hard drive. Checksum matches.
      I didn't backup my old bios manually (how stupid I am). But I remember the phoenix flash tool do make a backup before flashing. Do you know where can I find it?
      Another stupid move I did is that I thought the Winbond chip is the BIOS so I flashed the capsule file into it. Is it gonna be alright?
      Thanks again
        • 20914
        The winbond chip is 1MB - W25Q80DV: 8M-bit/1M-byte .Read it again and post the backup here. The phoenix flash tool should make a backup called bios.bin (or something) from the 25LB64CSIG (8MB bios) ,search for it and post that if you can find it on the hard drive/ssd.
        EDIT: The 25LB64C is 1.8V so you`ll need a 1.8V adapter. If the chip isn`t in your support list choose Winbond W25Q64FW
        • NonaHarry
          • Sep 2020
          • 4
          • Hungary
          I'm not able to find the backup file. But the laptop back alive after I flash the bios file. However right now the laptop doesn't charge. The charging light does not light up when I plug in the type-c charging cable. And MTM, Lenovo SN and UUID number in the bios is "INVALID". Does these happen because I accidentally overwrite the Winbond chip?
          I have totally no idea what to do next.
            • 20914
            The UUID,serial etc are stored in the bios,(the EC sometimes)and as you didn`t make a backup its gone.Have another look for the bios backup,it could be called bios.bak ,search through hidden files and search by the date when you flashed the bios.If you can`t find the old bios its possible you may be able to add the info back using a tool called LVAR (lenovo variable tool),if you can`t find a copy on the forum search around for it.
            The charging problem is related to the EC,see the release notes for the issue.Run the bios update again to flash the bios/EC,and check if it offers to make a bios backup,and if so,what its called,you don`t want to overwrite the older bios backup,if there is one.
            https://pcsupport.lenovo.com/gb/en/p...loads/ds541891
            EC Notification:
            [Fixed] : None
            [Modified] : Modify PD Power supply logical to fix USB type-c charge issue.(226767)
              Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
              This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
              09-07-2024, 05:20 AM
              Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
              This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
              This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-07-2024, 05:00 AM
              Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook 3 Specification for Upgrade or Repair
              This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15ACH6 boardview and IdeaPad Gaming 3 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
