    Hi awesome badcaps community,
    I've also tried to patch the file.
    Unfortunately, it complains about my file. I've made a backup 3 times, compared all files and also verified the backups with:
    Code:
    flashrom --verify
    Is someone else able to patch it?
    Best
    syscall
    Behind every successful Coder there an even more successful DeCoder to understand that code - Anonymous
      Code:
      flashrom --verify
      Best
      syscall
      Try this file ...
        Originally posted by Markus1741 View Post
        Try this file ...
        Hi @Markus1741,
        thank you very much for your support. I'll try out the file.
        Did I something wrong or have you patched it manually?
          Hi @Markus1741,
          Hello, I can't say that because I don't use Microsoft to create patches.
          Greetings to Switzerland.
            Strange, I also used a debian machine. But good to know that the script is working with my binary. I will investigate what might went wrong. Maybe will also apply your nice German translations. :-)
            BTW: The patch worked like a charm. Thanks again!
            Greetings to Bavaria
              Me be that helps in Debian GNU-Linux ...
              https://www.badcaps.net/forum/showpo...&postcount=358
                Hello, nice that it works. I know the resistor is type 0201 and is very difficult to solder without a microscope.
                This happens very often in this forum that the resistances are broken off, and then suddenly nothing works.
                I guess it comes with experience – you see the symptom and immediately know the common cause
                In such a case it is often better to solder fine wires to pin 1,2,4,5,6,8 it is much safer.
                I will (or use a clip)… if I ever have to do it again (which I doubt, but who knows)
                Greetings to Poland
                Thanks Markus, and greetings to Germany!
                  Unfortunately, I'd already the permissions set.
                  The issue was caused by some files I forgot to remove from the DXE folder after experimenting. Shame on me.
                  As I've read in this thread that I was not the only one who ran into this issue.
                  To give something back to this awesome community and thread, I've adjusted the script a little bit:
                  * Added support for MacOS.
                  * Added a README.md with the content of the TO's first post.
                  * Added some additional information to the user when he runs in a similar issue.
                  Hope it helps someone to prevent future (layer 8 ) issues.
                    Zip file error.
                    Become a Badcaps supporter
                    Thanks to all supporters.
                      Hello, thank you for your work.
                      The following happened to me too, apparently no one cares.
                      https://www.badcaps.net/forum/showpo...postcount=2073
                      IMPORTANT: Before applying the patch make sure you verify that your original image is not corrupted by dumping 1 or 2 additional images from your bios chip and comparing them. The original dump is THE ONLY WAY to recover your machine if something goes wrong!
                      It is not uncommon for users to accidentally delete or otherwise lose their original backup. And then what ...
                        Look ...
                          Originally posted by hoaca388 View Post
                          Zip file error.
                          Sorry, I zipped it again. Can you try it again please?
                          Unfortunately, I couldn't find a way to edit my previous post.
                            Do you mean we should show a warning before patching the file or just adjusting the message of the --howto flag and in the README?
                              can this work on 9th gen lenovo?
                                I don't think so (if you mean with gen9 the X1 Carbon). Because it has also the 11th Generation Intel® Core™ i5-1135G7 and Markus1741 mentioned that only 4th to 8th gen of Intel CPUs are supported:
                                Unfortunately this is not possible the Autopatcher only works from the 4th Gen to 8th Gen
                                You have.
                                11th Gen Intel® Core™ i7-1185G7 vPro®
                                  Originally posted by lapfix View Post
                                  Maybe someone give me help !
                                  I try this patch with Lenovo thinkpad x390 yoga , when first try the patched file the lap is on for 10 seconds ( black screen) than off, than on whith a continious beep ( always black screen ).
                                  this my main dump
                                  i have same problem any help..?
                                  here my original file
                                    Hi artani,
                                    Have you tried to flash it again? Did you hold (or taped) down the temper switches and removed the hard disk for the whole patch process?
                                      I've patched many and never had any problems, bu now I have T550 adn I have a problem with patching my file. I got:
                                      Using UEFIReplace to inject 2 DXE drivers...
                                      [1/2] BootOption (GUID e0746c42-d3f9-4f8b-b211-1410957b9ff5)
                                      [2/2] LenovoTranslateService (GUID 826bcf56-bac4-43f4-8ea1-8cdf0a121abd)
                                      Looking for volumes to patch...
                                      [1/1] NVRAM_EfiSystemNvDataFvGuid (checksum 2609h):
                                      Not found... Skipping.
                                      Done.
                                      PATCH FILE: T550_oryginal_PATCHED.bin
                                      Good luck.
                                      Using autopatcher_0.3
                                      Tried drag and drop inot the "Autopatch.py".
                                      Laptop stops on "ThinkPad To interrupt normal startup, press Enter", but when I press Enter nothing happens. Any solutions?
                                        Done.
                                        Good luck.
                                        Hello, I had the exact same problem with the same model.
                                        I think it is due to a corrupted ME region in the original BIOS file.
                                        At that time nobody wanted to help me either, I'll try it once.
                                        Greetings to Poland.
                                        https://www.badcaps.net/forum/showpo...postcount=1278
                                          Unfortunately it didn't change anything, it's still hanging on a black screen.
                                          Anyway, thank you very much for your efforts/time and greetings to you my German neighbor.
