Lenovo l470 dl470 nm-b021
    Re: Lenovo l470 dl470 nm-b021
    thanks it's work
      Hello friends
      I have lenovo thinkpad l470 rev. 2.0
      Problème
      Black screen
      I affiched extrenal screen it is ok
        hi can anyone help me with removing password from this plz
        much appreciated
          much appreciated
          https://www.badcaps.net/forum/showthread.php?t=87588
          Become a Badcaps supporter
          Thanks to all supporters.
            i cant seem to get it to run
              Of course it will never work for you because you misplaced the bios file of the HP ProBook 450 G5.
                come again !? , what are you on about
                  much appreciated
                  Hello, it looks like your original BIOS is damaged, I can't create a patched file from it.
                  Attempt to read the BIOS file at least 3 times and compare them so that they are identical.
                  "IMPORTANT: Before applying the patch make sure you verify that your original image is not corrupted by dumping 1 or 2 additional images from your bios chip and comparing them.
                  The original dump is THE ONLY WAY to recover your machine if something goes wrong!"
                    The file he posted is from an HP ProBook 450 G5
                      No it is a Lenovo L470 BIOS File ...
                        Are you sure ?
                          Are you sure ?
                          Hello hoaca388 you may be right with your assumption.
                          The file can't be patched at all, then it doesn't make any sense.
                          If I search wxHexEditor for L470, it just shows me the result as in the picture.
                          I wish you a nice day.
                            Your information is not wrong, don't know what he did before but that file has a part in the bios region that belongs to HP, the rest is from Lenovo.
                              You`re both right, its a frankenbios ,L470 and 450 G5
                                thinkpad l470 bios clean me region needed
                                the model number of motherboard is
                                DL470 NM-B021
                                the main problem of the laptop is that its freeze or hang whenever its on POST it does not boot to operating system
                                i will drop the old bios bin here
                                  Re: thinkpad l470 bios clean me region needed
                                  DL470 NM-B021
                                  Write your Device Serial Number.
                                  all donations are welcome,
                                    here is the serial number :PF-12XW3Y
                                      Here's your New BIOS, try it and let me know.
                                        hello.
                                        please remove password and fix bios for lenovo l470.
                                        takes over 30 sec for logo and its freeze and stuck on logo.
                                        DL470 NM-B021
                                        REV 2.0
                                        2017-06-02
                                        thank you in advance.
                                          It works well with dump from post #4.
                                          Thank you.
