Lenovo l470 dl470 nm-b021
  • rachidell
    • Aug 2016
    • 135
    • algeria
    Re: Lenovo l470 dl470 nm-b021
    thanks it's work
    • boussaa islem
      • Nov 2018
      • 30
      • ALGRIA
      Hello friends
      I have lenovo thinkpad l470 rev. 2.0
      Problème
      Black screen
      I affiched extrenal screen it is ok
      • roli1980
        • Nov 2020
        • 46
        hi can anyone help me with removing password from this plz
        much appreciated
        • hoaca388
          Badcaps
          • Jan 2022
          • 11784
          much appreciated
          https://www.badcaps.net/forum/showthread.php?t=87588
          • roli1980
            • Nov 2020
            • 46
            i cant seem to get it to run
            • hoaca388
              Badcaps
              • Jan 2022
              • 11784
              #26
              Of course it will never work for you because you misplaced the bios file of the HP ProBook 450 G5.
              • roli1980
                • Nov 2020
                • 46
                #27
                come again !? , what are you on about
                • Markus1741
                  • Sep 2020
                  • 843
                  • N/A
                  #28
                  much appreciated
                  Hello, it looks like your original BIOS is damaged, I can't create a patched file from it.
                  Attempt to read the BIOS file at least 3 times and compare them so that they are identical.
                  "IMPORTANT: Before applying the patch make sure you verify that your original image is not corrupted by dumping 1 or 2 additional images from your bios chip and comparing them.
                  The original dump is THE ONLY WAY to recover your machine if something goes wrong!"
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11784
                    #29
                    The file he posted is from an HP ProBook 450 G5
                    • Markus1741
                      • Sep 2020
                      • 843
                      • N/A
                      #30
                      No it is a Lenovo L470 BIOS File ...
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11784
                        #31
                        Are you sure ?
                        • Markus1741
                          • Sep 2020
                          • 843
                          • N/A
                          #32
                          Are you sure ?
                          Hello hoaca388 you may be right with your assumption.
                          The file can't be patched at all, then it doesn't make any sense.
                          If I search wxHexEditor for L470, it just shows me the result as in the picture.
                          I wish you a nice day.
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11784
                            #33
                            Your information is not wrong, don't know what he did before but that file has a part in the bios region that belongs to HP, the rest is from Lenovo.
                              • 20966
                              You`re both right, its a frankenbios ,L470 and 450 G5
                              • Zickko10
                                • Sep 2021
                                • 83
                                • Nigeria
                                #35
                                thinkpad l470 bios clean me region needed
                                the model number of motherboard is
                                DL470 NM-B021
                                the main problem of the laptop is that its freeze or hang whenever its on POST it does not boot to operating system
                                i will drop the old bios bin here
                                • hardware1
                                  • Sep 2021
                                  • 2936
                                  • N/A
                                  #36
                                  Re: thinkpad l470 bios clean me region needed
                                  DL470 NM-B021
                                  Write your Device Serial Number.
                                  all donations are welcome,
                                  • Zickko10
                                    • Sep 2021
                                    • 83
                                    • Nigeria
                                    #37
                                    here is the serial number :PF-12XW3Y
                                    • hardware1
                                      • Sep 2021
                                      • 2936
                                      • N/A
                                      #38
                                      Here's your New BIOS, try it and let me know.
                                      • bogdan039
                                        • Dec 2018
                                        • 57
                                        • Romania
                                        #39
                                        hello.
                                        please remove password and fix bios for lenovo l470.
                                        takes over 30 sec for logo and its freeze and stuck on logo.
                                        DL470 NM-B021
                                        REV 2.0
                                        2017-06-02
                                        thank you in advance.
                                        • bogdan039
                                          • Dec 2018
                                          • 57
                                          • Romania
                                          #40
                                          It works well with dump from post #4.
                                          Thank you.
                                            Lenovo ThinkPad L470 Notebook L Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad L470 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L470 boardview and L470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                            09-06-2024, 09:10 AM
                                            09-06-2024, 09:01 AM
