dump for Aspire A515-54
    Hi. need working dump for Aspire A515-54-333s . Motherboard DA0ZAWMB8E0 REV E.
    Laptop starts, .fan spin up.,no display.
    Please fix my BIOS dump.
    Re: dump for Aspire A515-54-333s
    Your bios merged with acer latest update firmware. If this bios doesnt work, your issue is not related to bios. Good Luck
      Thanks for help! Didn't work, problem elsewhere.
        Try this bios .
          Originally posted by SMDFlea View Post
          Try this bios .
          Didn't work. Thanks anyway.
            NEED HELP PLZ BIOS CRASH Aspire A515-54
            Nom du modèle: A515-54 | Référence: NX.HDDEF.005
            SNID:94406721676
              Try This
              Identical motherboard
                Hello, I need the acer a515-54-557c bios MAIN and EC ITE, SNID 118012071935.
                My backup is attached.
                  Vesko356 commented
                  Editing a comment
                  Read the rules before posting
                  You MUST
                  • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
                My board does not generate main on voltage, I suspect a problem with the EC file.
                  Good morning, can someone get this file for me?
                    I am working on ACER Aspire A515-54-74LM Serial # NXHNAAA00693913C647600 (SNID: 93908099676 ). Motherboard DA0ZAWMB8G0 Rev.G (UMA, no video chip on this board). It turns on fine but when booting to Windows, it give errors. I re-loaded Windows 11, but just freezes, I think the clean-me region has to be re-built. Can some do this for me or teach me how to do it. Thanks in Advance.
                      try
                        Originally posted by qayyum786 View Post
                        try
                        PERFECT!!! ... works 100% fine.. but still freezes when loading Windows 11, I will check further... Thanks for the help dear.
                          need help with bios A515-54 DA0ZAWMB8G0 REV G
                          A515-54-587L
                          model number N18Q13
                          SERIAL NXHQMAL005042012D59Z00
                          Tried some bios but too long to video.
                          backup attached.
                            SMDFlea commented
                            Editing a comment
                            Thread merged.
                          Hello, I leave you a backup with CleanME made and tested of the Acer Aspire A515-54-36VC with i3-10110U CPU (Comet Lake). Greetings
                            Working BIOS for this model:
                            Model: A515-54
                            Description: A515-54-34LR
                            Part Number: NX.HMDAL.02J
                            SN: NXHMDAL02J13814FFE7600
                            SNID: 13808601476
                            BOARD: DAZAWMB18B0 REV:B
                            CPU: SRGL0 (I3-10110U)
                            BIOS: V1.22
                            • peste
                              peste commented
                              Editing a comment
                              merged post..
                            Hello., I am working on this ACER Laptop Model: A515-54-5812. The Laptop works fine., But after about any moment & time the LCD Screen goes blank & unless & until the Notebook is not turned off & turned on after a while, then only I can see the display again. I just need the Original BIOS to be cleaned, hopefully this may be the problem. I have uploaded the Original BIOS Bin File.
                            Serial #: NHQ59AA0020400A9CE3400
                            SNID: 04004347034
                            Motherboard # LA-H501P Rev: 1A
                            Thanks in advance
                              SNID: 04004347034
                              Thanks in advance
                              Nitro AN515-54
                              Become a Badcaps supporter
                              Thanks to all supporters.
                                Originally posted by hoaca388 View Post
                                Nitro AN515-54
                                Thank you very much @hoaca388., Programmed the BIN file onto the chip. Tested for more than 2 hrs, uptill now no blank screen (the screen used to go blank in 15 ~ 1 hrs) . Hopefully the problem is fixed. Thank you very much dear....
                                  When my bios is on, auto on is off. When I hit the other bios, it turns on but the hard disk is not detected.
                                  Acer Aspire A515-54 series
                                  model N18Q13
                                  da0zawmb8g0 rev g
                                  Please Help me
                                  • peste
                                    peste commented
                                    Editing a comment
                                    post moved..
