Please Help Apple macbook pro A1708 EMC 3164 efi Lock
  • iori1881
    • Sep 2023
    • 58
    #41
    Re: Please Help Apple macbook pro A1708 EMC 3164 efi Lock
    Originally posted by smdflea
    post #14 has clean me firmware, just need to add your serial to that bios and change the fsys checksum.
    https://www.badcaps.net/forum/showpo...43&postcount=5
    4.3. Apple
    where is post 14 ?
      • 21932
      Originally posted by iori1881
      sorry but i didn't understand ... I said i erased bis chip by mistake
      So now you don`t have a backup, thats why you must use another bios.As i said,you must edit the serial number thats already in the bios and add yours.After that the fsys checksum has to be changed.
        • 21932
        where is post 14 ?
        Look on the black bar of each post on the right hand side,there`s a post number. Here it is anyway https://www.badcaps.net/forum/showpo...8&postcount=14
        • iori1881
          • Sep 2023
          • 58
          #44
          look on the black bar of each post on the right hand side,there`s a post number. Here it is anyway https://www.badcaps.net/forum/showpo...8&postcount=14
          unfortunatly this file does't work
          • iori1881
            • Sep 2023
            • 58
            #45
            i think i found the backup file
            • MuertoGB
              • Sep 2021
              • 94
              #46
              @iori1881
              Firstly, this is a telling off, stop erasing chips 'by accident', this is the second time. Please learn to do it properly, take the time to learn what you're doing wrong. There is some excellent information here by piernov:
              https://www.badcaps.net/forum/showthread.php?t=103528
              Second, the firmware you last uploaded is corrupted.
              Your new bios is attached; I used the file from post#14 and inserted your serial into the Fsys Store and cleared the NVRAM, please try it and write back.
              • iori1881
                • Sep 2023
                • 58
                #47
                Originally posted by MuertoGB
                @iori1881
                unfortunetly does't work...its not turning on
                • MuertoGB
                  • Sep 2021
                  • 94
                  #48
                  In that case, I've built a factory image from the repo, placed a donor Fsys store in the NVRAM at 0x20000h, and inserted your serial number. I have personally tested this firmware and it works. Please try it and write back. You must write it with your programmer, and then verify that data was written correctly.
                  • iori1881
                    • Sep 2023
                    • 58
                    #49
                    thank you very much , works fine.
                    • webhost
                      • Aug 2019
                      • 86
                      • Belgium
                      #50
                      Hello
                      need unlock this bios
                      Model A1708 EMC 3164
                      Serial Number : C02W81D8HV2F
                      thank You .
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12330
                        #51
                        Originally posted by webhost
                        hello
                        model a1708 emc 3164
                        serial number : C02w81d8hv2f
                        thank you .
                        aaa
                        • webhost
                          • Aug 2019
                          • 86
                          • Belgium
                          #52
                          Originally posted by hoaca388
                          aaa
                          power on for 10 second then turn off
                          • MuertoGB
                            • Sep 2021
                            • 94
                            #53
                            The previous file was not unlocked properly, and the EFI lock is still present anyway.
                            Try this and write back.
                            • webhost
                              • Aug 2019
                              • 86
                              • Belgium
                              #54
                              work Perfectly , Thank You So Much
                              • bibi019
                                • Jun 2014
                                • 59
                                • algeria
                                #55
                                i need unlocked file for my macbook pro WITH EFI LOCK A1708 emc 3164 sn C02V9FM9HV22
                                • MuertoGB
                                  • Sep 2021
                                  • 94
                                  #56
                                  EFI lock invalidated, VSS cleared. Try this and write back.
                                  • bibi019
                                    • Jun 2014
                                    • 59
                                    • algeria
                                    #57
                                    not power on only fan works for 10s then nothing happend it stoped. and the mac not power on
                                    any hope
                                    • peste
                                      • 13619
                                      • ROMANIA
                                      #58
                                      try..
                                      • farouk_1994
                                        • Mar 2021
                                        • 398
                                        • algeria
                                        #59
                                        Originally posted by X-FILES
                                        buenos días, tengo una macbook pro a1708 EMC:3164 BIOS MUERTO, AGRADECERIA si me pueden ayudar
                                        Perdon por el error
                                        Write in english only according to the rules
                                        • vxn91607
                                          • Nov 2023
                                          • 5
                                          #60
                                          Hello, I need an unlocked bios for MacBook Pro A1708, EMC 3164, Serial number: C02VQNXAHV22, unfortunately the current memory is damaged and it is not possible to read the old firmware, the previous memory had an EFI lock.
                                          Thank you in advance
