x260 supervisor
Bought a used laptop years ago, cant enable the virtualization on it becuase of supervisor password so here I am.
I couldn't find anything detailed explained for X260, and I'm a total noob.
1. Where is EEPROM located on the board, do I need to disassemble the whole thing, or is it a case of popping a back cover?
2. I have the CH341A, I don't have a SOIC8 clip, I have almost f* up another board trying to de-solder the eeprom from it - it wasnt a laptop. So I guess SOIC clip is a must
3. What when I get to read the EEPROM data ( i have heared it's around 16 mb )
https://www.badcaps.net/forum/showth...ad.php?t=87588
-Download this, run the scrip on my original dump and flash it on the laptop EEPROM ?
And it's a job done?
STEP 8: Restore original BIOS
- I again reflash the original that I've read off the laptop eeprom?
Cheers
unlock password on thinkpad x260
Re: unlock password on thinkpad x260
Originally posted by danandrei96 View PostHi! I've tried some of the files on here and also used the autopatcher on my own bios dump, but the laptop always gets stuck on the boot screen with the big lenovo logo where it says "press enter to interrupt blablabla" (yes, I pressed enter, nothing happened).
Can someone help me please? I've attached the bios dump below.Attached Files
Originally posted by wajdi.hamed View Postit works but it blocked on the start screen
i test with "PATCH 1 X260 PSW.rar " and my thinkpad cant run. if i plug the charger the keyboard lights on for few sec and thats it. after only green light ...
Hi all
someone can help me to remove biospwd from this lenovo x260 NMA581. I used
lenovo autopatcher 0.2 but it give 5beepx2. I don't know what's happened because
I made as tutorial said.
I'll attach the two dump (origin and patched)
Thanks in advanceAttached Files
Re: thinkpad x260 unlock
Originally posted by didouche1200 View Postplease help me to patch locked bios thinkpad x260
STEP 2: Boot the machine
STEP 3: Press ENTER/F1/etc. to enter BIOS settings
STEP 4: Enter any character when asked for Supervisor Password
STEP 5: Press enter when it shows Hardware ID
STEP 6: Press space bar 2x when asked
STEP 7: Turn off machine
STEP 9: Reset BIOS settings to factory defaulTAttached Files
please help me to patch locked bios thinkpad x260Attached Files
please help me to patch bios for thinkpad x260Attached Files
Originally posted by Mazorca View PostDid you desolder in order to read chip? Then solder it back with the patched file? If so, resolder chip, I myself use hot air then the iron tip just to make sure the legs are fully seated. It happened to me twice on two X250, there was a lot of lead (not needed) under the Bios chip. I just took it all off.
By the way, I have had bad luck with reading chips with the wired clips, I don't trust them.
Originally posted by Mazorca View PostHere is your patched file, follow instructions on #20.
For search purposes, it is recommended that next time you open a new thread if asking for password, this one is for x260, not x240.
By the way, both the original files are the same, good job on making at least two, they are extremely important.
By the way, both the original files are the same, good job on making at least two, they are extremely important.Attached Files
Can someone add patch fo password removal for this bios dump? Its from x240 with i7, board NM-A091 rev1.0.Attached Files
so many thanks*qayyum786* it's work well.very thanks
so many thanks * qayyum786 * it's working well.very thanks your help.Last edited by bestechrepairs; 04-02-2021, 09:17 AM.
Originally posted by qayyum786 View Posttry this given bios write the bios and check if you will not get any beep sound than you are good to go for below given steps
STEP 1: Flash Given PATCHED Bios
STEP 3: Press ENTER/F1/ to enter BIOS settings
STEP 4: Enter 1234 when asked for Supervisor Password
{Now 1st part is complete }
STEP 8: now You Have To Remove the bios chip & write your old original backup bios (x260.rar)
STEP 9:Start Laptop Go to bios setting by pressing F1 & Reset BIOS settings to factory default save and exit
