unlock password on thinkpad x260
  • andresi
    • Nov 2020
    • 154
    • INDONESIA
    Re: unlock password on thinkpad x260
    Originally posted by qayyum786
    did you try WITH FLASH bios from another dump ?
    read this post if you have administrator password
    https://www.badcaps.net/forum/showthread.php?t=87588
    i already try this, but i got 5x2 beep and off
    • qayyum786
      • Aug 2018
      • 1959
      • INDIA
      is it administrator password ?
      • andresi
        • Nov 2020
        • 154
        • INDONESIA
        yes
        • qayyum786
          • Aug 2018
          • 1959
          • INDIA
          try this given bios write the bios and check if you will not get any beep sound than you are good to go for below given steps
          STEP 1: Flash Given PATCHED Bios
          STEP 2: Boot the machine
          STEP 3: Press ENTER/F1/ to enter BIOS settings
          STEP 4: Enter 1234 when asked for Supervisor Password
          STEP 5: Press enter when it shows Hardware ID
          STEP 6: Press space bar 2x when asked
          STEP 7: Turn off machine
          {Now 1st part is complete }
          STEP 8: now You Have To Remove the bios chip & write your old original backup bios (x260.rar)
          STEP 9:Start Laptop Go to bios setting by pressing F1 & Reset BIOS settings to factory default save and exit
          • andresi
            • Nov 2020
            • 154
            • INDONESIA
            thank you
            • bestechrepairs
              • Nov 2018
              • 20
              • sri lanka
              #26
              so many thanks * qayyum786 * it's working well.very thanks your help.
              • bestechrepairs
                • Nov 2018
                • 20
                • sri lanka
                #27
                so many thanks*qayyum786* it's work well.very thanks
                • lukas1_0
                  • Dec 2020
                  • Polska
                  #28
                  Can someone add patch fo password removal for this bios dump? Its from x240 with i7, board NM-A091 rev1.0.
                  • Mazorca
                    • Jan 2017
                    • 463
                    Here is your patched file, follow instructions on #20.
                    For search purposes, it is recommended that next time you open a new thread if asking for password, this one is for x260, not x240.
                    By the way, both the original files are the same, good job on making at least two, they are extremely important.
                    • lukas1_0
                      • Dec 2020
                      • Polska
                      #30
                      Thanks you for your reply and forgive me for posting in this thread regarding different laptop model. Unfortunately after fallowing instructions and flashing original bios file laptop doesn't turn on, it just flashes 3 times with power button and backlight keyboard flashes one time. Nothing happens other than that.
                      • Mazorca
                        • Jan 2017
                        • 463
                        Did you desolder in order to read chip? Then solder it back with the patched file? If so, resolder chip, I myself use hot air then the iron tip just to make sure the legs are fully seated. It happened to me twice on two X250, there was a lot of lead (not needed) under the Bios chip. I just took it all off.
                        By the way, I have had bad luck with reading chips with the wired clips, I don't trust them.
                        • lukas1_0
                          • Dec 2020
                          • Polska
                          #32
                          I tried desoldering chip and soldering in programmer and to my suprise it worked. Laptop is turning on and the password is removed. Before I tried with clip, I checked couple of times if writing was correct and everything was, so I don't know why that happend.Thank you very much for your help.
                          • didouche1200
                            • Oct 2016
                            • 370
                            • 82679911441
                            #33
                            thinkpad x260 unlock
                            please help me to patch bios for thinkpad x260
                              • 22135
                              Re: thinkpad x260 unlock
                              This isn`t the bios requests forum
                              • piernov
                                • Jan 2016
                                • 4439
                                • France
                                #35
                                Uh, moved just after you replied…
                                • didouche1200
                                  • Oct 2016
                                  • 370
                                  • 82679911441
                                  #36
                                  please help me to patch locked bios thinkpad x260
                                  • shabi
                                    Banned
                                    • May 2019
                                    • 147
                                    • pakistan
                                    #37
                                    STEP 1: Flash and replace current BIOS with the generated patch file
                                    STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                                    STEP 4: Enter any character when asked for Supervisor Password
                                    STEP 8: Restore original BIOS
                                    STEP 9: Reset BIOS settings to factory defaulT
                                    • didouche1200
                                      • Oct 2016
                                      • 370
                                      • 82679911441
                                      #38
                                      it works but it blocked on the start screen
                                      • didouche1200
                                        • Oct 2016
                                        • 370
                                        • 82679911441
                                        #39
                                        thanks its work
                                        • razadom
                                          • Apr 2015
                                          • 105
                                          • Madagascar
                                          #40
                                          Hi all
                                          someone can help me to remove biospwd from this lenovo x260 NMA581. I used
                                          lenovo autopatcher 0.2 but it give 5beepx2. I don't know what's happened because
                                          I made as tutorial said.
                                          I'll attach the two dump (origin and patched)
                                          Thanks in advance
                                            Lenovo ThinkPad X260 Notebook X Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad X260 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X260 boardview and X260 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                            09-06-2024, 08:10 AM
                                            09-06-2024, 07:07 AM
                                            09-06-2024, 07:05 AM
                                            09-06-2024, 06:58 AM
