lenovo ideapad s130-11igm need bios bin
    no display
    board id
    s130/130s-glk-mb-lpddr4-v10
    my backup..https://www.4shared.com/file/fnSDeRS...0s_backup.html
    tnx advance
    Re: lenovo ideapads130-11igm need bios bin
    Virgin Bios extracted from lenovo update. Give feedback
    PS:Always upload bios backup here and not those 4shared links.
      It works perfectly, thank you!
        its working perfect
          Thanks a lot mcplslg123
          The bios works for us __our chip was GD25LB64 LENOVO IDEAPAD S130-14IGM ___MACHINE BOOT
            Super! The bios works. Thanks
                just a quick question. I have black screen and can't load the windows. how do you overwrite the bios file? do you use flash bios programmer?
                  Brilliant,worked a treat.Thank you
                    I used a CH341A Black edition (ebay £4.70).
                    Downloaded the bin file above and it works perfectly.
                    I had to unsolder the bios chip 25LB64CSIG and soldered it onto the small board that came with the programmer kit then simply programmed it with the bios file and viola,all working.
                      Is a 1.8 volt adapter used or does it go directly to the programmer? Beforehand thank you very much.
                        Thank you it worked for me.
                          Thank you for the bios file. It works.
                            the file was corrupted, can you resend it?
                              File is working 100% thanks
                                thanks working for me
                                  Can you help me understand how to read this chip? i have tried tw0 programmers and fail to detect its model
                                    Hi
                                    attached bios dump for this laptop.
                                    can you please give a working bios ?
                                      Originally posted by koby058 View Post
                                      Hi
                                      Your serial number ?
                                      Become a Badcaps supporter
                                      Thanks to all supporters.
                                        Yd063ufb
