Originally posted by wangbreeze
View Post
mec 16xx dump with info block
Originally posted by vuquanghoanh View Post
Sure. I have successfully entered the brand name. Just like in the photo.
But every time I start up, the laptop still reports error 2202.
I don't know what to do anymore
otherwise use planar service with your serial
https://www.badcaps.net/forum/troubl...id#post3220825Last edited by Maxpower3; 02-21-2024, 10:29 AM.
Originally posted by vuquanghoanh View PostI have successfully removed EC password. The system has received complete information. But when starting the laptop there is still message 2202: Product name is invalid.
I used the Gold key to re-enter the information but the problem was not resolved.
Has anyone solved this problem yet?
Thanks,
Originally posted by Maxpower3 View Post
not 7th gen just 7th
I have been trying to enter Brand name for 1 week but without success. With your guidance, I succeeded the first time.
Thank you so much.
Hello, maybe one of you can help me. I have 2 T14s laptops with board number NM-C891, after soldering the wires and moving the resistor, I still get the message in SVOD 4.
MEC IDCODE: B1240020
Device ID: 0
Device Revision: 0
Device Status: 0
Flash Status: 0000000000
Boot Block in not protected mode
the reading is empty every time. I will add that in the X390, where the board is very similar, I managed to do it every time. Maybe someone had a similar problem ?
Originally posted by mily.gawel View PostHello, maybe one of you can help me. I have 2 T14s laptops with board number NM-C891, after soldering the wires and moving the resistor, I still get the message in SVOD 4.
Device ID: 0
Device Revision: 0
Device Status: 0
try
I've screwed up a T14 gen1 and now I need to erase the SVP to make it bootable again (0199 System Security error). I'm going to use a Vertyanov JIG V3 for that and I would like to avoid losing all OEM info and windows activation.
Originally posted by TigTex View Post
Hey Maxpower3, I've noticed that you've filled with F the blocks from 0x300 to 0x34F. Is this all it takes with all MEC1663 to erase SVP or was this something specific for this user's laptop?
just look at the following CON# (43 4F 4E 23 53 00 02 A8 F4) or BC B0 B1 DC AC FF FD 57 0B 02 A8) in Xor version.
Same principle for all, can be doubled on certain models
