HP Elitebook X360 1030 G4 BIOS unlock request
  • peste
    • 13573
    • ROMANIA
    #61
    Re: HP Elitebook X360 1030 G4 BIOS unlock request
    Originally posted by hashmiUNITED
    Please can someone check the 16MB bin file below. I tried loading it onto RC_unlocker but get the message - "Wrong chip, try reading and unlocking 16MB chip".
    Thanks.
    see that the posted content is longer than 16MB... read the chip one more time and try again..
    • hashmiUNITED
      • Mar 2023
      • 5
      #62
      Thanks I will try again.
      Also I used Dataman 48UXP to read chip, is this okay or should I order and use the CH341A programmer?
      • peste
        • 13573
        • ROMANIA
        #63
        I don't use any of them.. I don't know how to tell you.. try what you have and post again..
          • 21852
          It just needs the last 1KB trimming off. The programmer has saved SFDP timing information at the end.I googled what SFDP was so i could be wrong.
          Does the programmer have an option to save without SFDP ? ,can you use a hex editor to delete the unwanted 1KB at the end of the file
          https://cdn.badcaps-static.com/pdfs/...ef0c18f624.pdf
          • hoba0073
            • Apr 2022
            • Maroc
            #65
            Re: HP Elitebook X360 1030 G4 BIOS unlock request plz
            mx25L25673G 32MO
              • 21852
              mx25L25673G 32MO
              https://www.badcaps.net/forum/showpo...0&postcount=49
              https://www.badcaps.net/forum/showpo...3&postcount=57
              https://www.badcaps.net/forum/showpo...4&postcount=58
              Sometimes it helps if you read the whole thread first.
              • lapfix
                • Mar 2020
                • 2764
                • my workshop
                #67
                mx25L25673G 32MO
                First boot load bios factory defaults, save and exit and then at the next boot disable security options
                • hashmiUNITED
                  • Mar 2023
                  • 5
                  #68
                  Hi I have found SDFP and removed it from file but I still get the same message.
                  Please see attachements.
                  Thanks.
                  • hashmiUNITED
                    • Mar 2023
                    • 5
                    #69
                    Hi sorry pleae ignore my post above I misunderstood your post I deleted the last 1KB of the .bin file and now was able to use RC_unlocker.
                    However I have another problem the laptop does not seem to turn on. I get blinking orange and white light when I put it on charge and caps lock light is on all the time.
                    Do I need to reset CMOS settings somehow. Thanks.
                      • 21852
                      recheck all your soldering and look for any damaged or missing parts around the bios chip if you used a hot air station. Does this model have a CMOS battery, did you remove it. did you remove the main battery.
                      Flash the old bios back and see if there`s any difference
                      • techno.logic
                        • Mar 2023
                        First time messing with direct BIOS flashing here. Read and understood everything I could find, so please be gentle.
                        Got a CH314A black edition, did the 3.3v mod. Finally found a version of the software that Chrome and Edge said didn't have a virus in it. Hooked it up, detected the chip, there is no exact match for the chip. Have a Winbond W25Q128JV, ended up using BV. Every time I read the chip, validation fails. However, I was able to use RCUnlocker, and RC says it was able to complete the unlock.
                        Right now I'm attempting an in-circuit flash with all other power sources disconnected. When the software attempts to do the validation, it immediately fails, as if it can't read the chip the second time.
                        Since RCUnlocker reports it was able to do its job, should I just send it and flash the image? Or should I get this validation issue figured out first?
                        Thanks!
                        • alfredposadas09
                          • Aug 2020
                          • 342
                          • Philippines
                          #72
                          Yes validation is important
                          • hashmiUNITED
                            • Mar 2023
                            • 5
                            #73
                            Hi I managed to get the laptop back working again by flashing the old bios bin. However when I re-flash the unlocked bios bin I get both caps lock and num lock keys flash 7 times. Any reason why this might be?
                            Thanks.
                            • ahmedelwn
                              • Oct 2022
                              • 27
                              • egypt
                              #74
                              blink only
                              is there a solution
                              Thanks in advance
                              • afouad1602
                                • Apr 2018
                                • 5
                                • algeria
                                #75
                                need unlock bios hp x360 1030 g4
                                Proid 6mj73av
                                SN 5CD0101C29
                                BIOS DUMP 32MP
                                • brkicn
                                  • 6
                                  • Србија
                                  #76
                                  Hello, i have HP Elitebook x360 1030 g4 and i did unlock similar HP with CH341A but now something not ok. This is dump i read. I try unlock with RC Unlocker v1 and back to bios but nothing.
                                  I did verify after read and everything OK. Have 2 identical HP and curious what is wrong?
                                  THANK YOU!
                                • brkicn
                                  • 6
                                  • Србија
                                  #77
                                  Serial number:
                                  5CD952DDNN
                                    HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) Specification for Upgrade or Repair
                                    This specification for the HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 boardview and EliteBook x360 1030 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                    09-06-2024, 08:27 AM
                                    HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) Specification for Upgrade or Repair
                                    This specification for the HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 (ENERGY STAR) boardview and EliteBook x360 1030 G2 (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                    09-06-2024, 06:40 AM
                                    09-06-2024, 05:33 AM
                                    HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) Specification for Upgrade or Repair
                                    This specification for the HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EquipoEliteBook x360 1030 G4 boardview and EquipoEliteBook x360 1030 G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                    09-06-2024, 11:32 AM
