Hp elitebook 840 g5 bios password
    Re: Hp ellİtebook 840 g5 bios password
    Could you guys help me with resistor value near pin 7 of Bios (post 63) i accidentally wiped him away with wick from the board Is it 3,3k omh ?
      Originally posted by NaneName View Post
      Hi all!
      Probe delivered. But the situation is bad. All 5 readings gave different results.
      The situation by region is in the attachment.
      "+" - match
      "-" - difference
      Is the 3rd reading correct? For flashing, the chip will be soldered.
      Post 3rd result. The 3rd read I saw enough areas of the bios file.
      Become a Badcaps supporter
      Thanks to all supporters.
        In case anyone will need it, i find out its value of 15 Ohm, be aware there are different configurations of traces layout on motherboards. Mine corresponds to photo from post 63 (6050A2945601-mb-a01).
          help me plz i want clean the admin password from this bios elitebook 830 g5 thank you
              Originally posted by satishkumar View Post
              not working the fun starting and no stoping
                Here's your Unlocked file, in the first boot go to bios menu and disable security options (Default).
                If that password still exist, upload the other chip (EC) it could be 16MB or 32MB.
                all donations are welcome,
                  thank you the first bios it s working
                    Originally posted by mah3r0
                    I need bios dump file bin for hp 15-fa0031dx
                      Hi,just tried to unlock my hp 840G5 Bios with thetool from the first page on https://www.badcaps.net/forum/showthread.php?t=103184, but it doesn't worked. As there are two IC's which belongsto the BIOS, I'm not sure if I did it with the right one. So question first, is the large 32MB the right one and if yes, is somebody able to do the unlock of my attached one?
                        Try this file
                        Product name : HP EliteBook 840 G5
                        Serial number : 5CG8291RP1
                        SKU : 3RF16UT#ABA
                        Build ID : 17WWCSAT601#SABA#DABA
                        Fearture byte : 3X476J6S6b7B7H7M7Q7W7m7saBapaqauawb8bUbhcAdUdpdqgdhKhkjh.5F
                          great works!!!
                          How do I update now the lost device details,likethe srial number etc.?
                            the laptop is currently in step 30 of the manufacturing program mode...
                              press F10, in "Main" you have a tab "set machine unique data" and write all data hoaca388 gave you. After that use BCU 4.0 to exit MPM mode or restart laptop 27 times or whatever counter shows.
                                Done
                                  HP 840 G5 Bios unlock
                                  Hi Guys,
                                  Can someone help me with unlocking this BIOS ?
                                  I tried RCunlocker and HPUnlocker but password @ Power-On Authentication is always there.
                                  Can someone unlock it for me please?
                                    Re: HP 840 G5 Bios unlock
                                    Originally posted by repairit.ie View Post
                                    Hi Guys,
                                    also post the content of the other bios chip..
                                      Here is the 32mb Bios
                                      Thanks!
                                        I used again HP unlocker and unlocked other 32mb bios. Programmed them into chips and there is no password.
                                        The only thing now is that computer displays "BIOS identity Data Needs To Be Restored. The embedded controller MUD data does not match the BIOS MUD data."
                                        Then Gives me two options RESTORE and DO NOT RESTORE.
                                        Restore option does not work, only when i click on DO NOT RESTORE computer loads to OS.
                                        There is couple of details missing in info about computer in BIOS like production date etc.
                                        Any way to fix this issue? Was there something that HPUnlocker did that this message came up?
                                          can someone help hp elitebook 840 g5 bios password file, i try to use hp unlocker to 32mb bios files do i need to unlock the ec file also using hp unlocker?
