Hp elitebook 840 g5 bios password
    Re: Hp ellİtebook 840 g5 bios password
    Originally posted by rachidell View Post
    not working
    Use the RCU with the dump from the second chip.
    Become a Badcaps supporter
    Thanks to all supporters.​
      not working
      Post the other bios in the bottom of your mb
        Hi , I have a HP 840 G5 with bios password, can anyone please help to remove password. I have attached the main bios file. Thank yoy
        At first start load bios defaults, save and reset.
        I don't provide help for people using CH341A and a clip.
          thank you
            840 G5 locked
            Hello
            i tried to remove the bios password from a 840 G5 with a program (32mb chip) now the caps lock and num lock keys blink 3 times and the fans spin all the time (screen stays black. when i restore the original bios file games on it comes again the same problem with the flashing keys and the fan. what can it be? can someone help me?
            edit: its a 840 g5 not g6
              try this
                There is a password in bios. can you help me please
                  Read post #201.
                    Re: HP BIOS unlock tool
                    Hello friends, i have this hp elitebook 840 g5. hp unlocker not working, password still present. I need some help.
                    There's original dump.
                      Read post #208
                        Can anyone please unlock this BIOS for me? Its for Hp 830 G5. Thanks in advance
                          This thread is for the 840 g5 ,not 830.Please read the rules.
                          You MUST NOT:
                          • Hijack threads unrelated to your request
                          You MUST:
                            is there any solution to the system end point controller issue?. I have 6050A2945601 with bios issue. I dont have the orig dumps as this came to me as dead, both ec and bios chip were worked on before. Found this bios and the unit powers up again but I now get the endpoint controller issue.
                              HP EliteBook 840 G5 Base Model Notebook PC
                                Hi do I not need a ec dump ?
                                  not working just black screen and current 221ma
                                    No way, review your process.
                                      You are right . The SIO was getting very hot. Thanks for your help.
                                        Could someone please confirm which chip (or both?) I should be flashing? Seems to be differing views unless I missed something.
                                        I used HPUnlocker on the 32MB 25Q256JV, resoldered & now the laptop has a blank screen & fans on high.
                                        I then tried to use RCU on the same chip as per one of the suggestions, but that doesn't work, telling me I should be flashing the 16MB chip.
                                        So do I need to do the 32MB chip, 16MB, or both?
                                        Thanks!
                                          Thanks!
                                          RC unlocker. Use rc unlocker for 16 MB chip.
