Acer aspire 3 a315-41 r740 bios
  • george_gpu
    • Dec 2015
    • 77
    • greece
    merry xmas to all
    i need bios for model n17c4 aspire3
    rev1.0 dh5jv la-g021p
  • george_gpu
    • Dec 2015
    • 77
    • greece
    Re: Acer aspire 3 a315-41 r740 bios
    bios chip is winbond w25q64fwsvig , is it 1.8 volt ?
    when i try to read with rt809 chip id error appear ,is it damage?
    • peste
      • Dec 2016
      • 13924
      • ROMANIA
      read here...
      https://www.badcaps.net/forum/showthread.php?t=63325
      • george_gpu
        • Dec 2015
        • 77
        • greece
        thanks 1.8 adapter i must use
        when i try to read with adapter 1.8 and clip pomona 8pin i steel get error chip id
        i must desolder to check
        doyou have bios bin ?
        • george_gpu
          • Dec 2015
          • 77
          • greece
          Problem with acer is i have red light and when i press power blink only
          Keyboard is ok
          With battery out i dont have any light
          I have 6volt on motherboard battery 2 Pins
          I make dicharge with button (swg2)
          Bios chip no voltage
            • 22293
            Keyboard is ok
            Check page 32 of the schematic,SWG1 BI SW ,battery in switch,it has to be pressed in for the battery to charge.It presses in when the case is screwed down.
            • george_gpu
              • Dec 2015
              • 77
              • greece
              I try it red light shut off when you pressed for 15 seconds
              Nothing at all
              https://www.flickr.com/photos/186208.../shares/72675J
                • 22293
                Desolder the bios,then see your programmer will read it.Post your bios backup if it does.If you don`t have 1.8V on pin 8 check schematic to find 1.8VALW voltage.
                • george_gpu
                  • Dec 2015
                  • 77
                  • greece
                  I dont have 1,8 on pin 8 for sure .tomorrow i try to read it first
                  if you can send me schematic + bios please
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    There are 2 types of bios in acer update for this model. I've tried to extract both. Try both and post feedback.
                    PSH5JV is likely your bios.So try this first.
                    • Minix0S
                      • Mar 2019
                      • singapore
                      ty it works.
                      • Andyservo
                        • Jun 2013
                        • 152
                        • Indonesia
                        Thanks mcplslg123...
                        • genese
                          • Sep 2012
                          • 5
                          • Phillippines
                          big thanks it works for me too.
                          • byrlopez
                            • Feb 2011
                            • 47
                            Thank you very much mcplslg123, you just had to open the original file and see if it uses one or another bios file, it served me perfectly, it is a misleading device, because seeing that it turns on without giving video makes a novice technician think that it is a problem with the GPU RYSEN and it is actually Corrupt BIOS problem.
                            • kalilinux25
                              • Mar 2018
                              • 2093
                              • ZAMBOANGA SIBUGAY
                              there are 2 types of bios in acer update for this model. I've tried to extract both. Try both and post feedback.
                              Psh5jv is likely your bios.so try this first.
                              working
                              • IZZADEEN
                                • Jul 2020
                                • 3
                                • INDIA
                                its courrupted
                                • IZZADEEN
                                  • Jul 2020
                                  • 3
                                  • INDIA
                                  During extract it will not extract,shown archieve file damage or currupted
                                  • peste
                                    • Dec 2016
                                    • 13924
                                    • ROMANIA
                                    update winrar or use 7zip
                                    • M4n0l0307
                                      • Nov 2020
                                      • 172
                                      • Republica Checa
                                      Thank You Friend !
                                      • Tobiichi33
                                        • Nov 2019
                                        • 11
                                        • indonesia
                                        Hello my friend can help me
                                        this bios password can help me anyone?
                                        • EbrahimSiami
                                          Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                                          by EbrahimSiami
                                          I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                                          **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                                          **What I have tried so far:**
                                          1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                                          07-02-2025, 02:31 PM
                                          ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 02:30 PM
                                          ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
