Dell Precision 7510 7710
    Re: Dell Precision 7510 7710
    Thanks PESTE
    iTS OK NOW I CAN SEE DISABLED OPTION ON BIOS
    thankss
    please NEED HELP WITH THIS OJNE TOO IF U CAN many thasnks
      Hi..i Have a Dell precision 7710 it only boots when you remove AC adapter, battery & Cmos connector, then plug in the adapter & turn on..display comes on only after 3-4 self restarts, it takes couple of minutes..is my bios bricked?
        No, if the bios is bricked the machine would not turn on at all. Check the power on switch, most probably this is the reason.
        Become a Badcaps supporter
        Thanks to all supporters.​
          Power switch is good...i can switch it off with it, it starts only when CMOS connector removed & 4-5 times cycling through finally it comes on, it stays on thereafter..I tried Dell diagnostics it gave error at webcam check..Is there a problem with webcam?
            i need clean me
              Originally posted by ameerrrr View Post
              i need clean me
              clear
                Originally posted by qayyum786 View Post
                clear
                Thanks it's working
                  Hi there try this one should works
                    please help me fix my dump, v1.15 worked for me but late display
                      Have you tried cleaning the ME firmware ? -> https://www.badcaps.net/forum/showpo...41&postcount=3
                        Already tested 100% ok file with clear me region
                          Request for repair bios for AAPAO LA-C541p rev 2.0 a01.
                          Dell 7510
                          Service tag: D4DS0G2
                          Thanks in advance!
                          Dell 7510
                          Thanks in advance!
                          Precision 7510
                          Service Tag: D4DS0G2
                            My bios chip is corrupted and there are no backup files left. I copied many files but image upload was 30 seconds slow. Help me LA- C541P rev 1.0
                            S/N: SF6LRC2 .thx
