hp 840 g6 6050A3022501-MB-A01
    Re: hp 840 g6 6050A3022501-MB-A01
    Hello, can anyone tell me that it's something different to remove bios password for 840 G6. Or i can use black0hackers Link?
      Upload your 16MB & 32MB dumps here.
      Become a Badcaps supporter
      Thanks to all supporters.​
        Take a look.
          Take a look.
            Already sent him the file to test FF it is
              Hmm. So should i use old 32 MB Chip and just reflash 16 MB? Do i need clean ME, copy win key?
                Originally posted by Rethorical AlltheCheese View Post
                FF it is
                Is it? All the way to the whole region?
                  Well, yup. I tested it on 840 G5 and G6. Worked on both. Throws an error at first but only once or twice. I'd call that a success. Already added it to my unlocker. Just finalizing it now, finally
                    Exactly
                    No, just program the 16MB chip only, and you are good to go.
                      Originally posted by RethoricalCheese View Post
                      Well, yup.
                      G-R-E-A-T!
                      As I already told you:
                        I can confirm that it's fully working. Thank you so much for the help guys.
                          any help with removing the bios password ? thanks
                            Sit tight, help is on the way.
                            P.S. Just sent you the file to test, try it & leave feedback.
                            P.S.2 Program only 16MB chip.
                              Thanks . is working
                                Thanks . is working
                                Great! You're welcome.
                                  HP Elitebook 840 G6 unlock plz
                                  HP Elitebook 840 G6
                                  part no.CRESCENT-6050A3022501 -MB-A01(A1)
                                  Plz Unlock.
                                    Re: HP Elitebook 840 G6 unlock plz
                                    Originally posted by salmanlxm View Post
                                    hp elitebook 840 g6
                                    part no.crescent-6050a3022501 -mb-a01(a1)
                                    plz unlock.
                                    Edit: File to test has been sent, try it & leave feedback.
                                      BTW your 32MB file is not OK, just in case try to read the chip again, and take good dump.
                                        HP 840 G6 BIOS locked
                                        Hi everybody,
                                        I'm trying to unlock the BIOS password of a HP 840 G6 Elitebook. I've unmounted the laptop to get access to the back part of the motherboard and unsolder the chip U366, a Winbond 25Q128JVPQ, which according to previous messages here seems to be the EC secondary BIOS chip for this laptop (see images attached). The chip comes in a WSON-8 6x5-mm package,
                                        https://www.winbond.com/resource-fil...021%20Plus.pdf
                                        so I soldered it in a little PCB adaptor (a workaround as I didn't have the right one: I had to put some squared tape in the central downside pad) in order to be able to read it an re-programming it by using the EZV 2019+ programmer (see also image attached).
                                        After reading it several times selecting a generic W25Q128 in the programmer, even slowing down the speed from 12 to 6 Mhz, the files read are identical and the contents seem to be similar to the files published in this thread. So far, so good
                                        Now I have to re-program it. I'm planning to use the following Python code to do it, adapted from the one from Peste and the posts from other members in this forum. The code just write a block of FFs folowing Peste's reverse engineering methdo However the starting address of the block to be overwrited seems to be different from other files posted in this thread which makes me somewhat unsecure about it. This is the code:
                                        Code:
                                        # Pyton script to fill block [d1-d2] of a binary file
                                         with the same byte value
                                        # Start and end addresses:
                                        #d1=226770
                                        d1 = 226824
                                        d2 = d1 + 1204
                                        # Byte value
                                        BYTE=b'\xff'
                                        import mmap, shutil, sys
                                        path = sys.argv[1]
                                        splitpath = path.split('.')
                                        newpath = splitpath[0] + '_unlocked.' + splitpath[1]
                                        shutil.copyfile(path, newpath)
                                        with open(newpath, 'r+') as f:
                                          with mmap.mmap(f.fileno(), 0) as m:
                                            print('working ...')
                                            m.seek(0)
                                            for j in range(d1,d2+1):
                                               m[j: j+1] = BYTE
                                               print(j)
                                            m.flush()
                                            m.seek(0)
                                          f.seek(0)
                                        print('\n Done.')
                                        # End
                                        I also attach the read file of the 16 Mb BIOS chip.
                                        Can you help me or send me an unlocked file?
                                        As I have no tools here I am in a hurry. I will, of course, reply with the results.
                                        Many, many thanx in advance and for supporting this forum and community.
                                          File sent. Try & leave feedback.
