Lenovo ThinkPad T470s BIOS
  • hoaca388
    • Jan 2022
    • 11111
    • Viet Nam
    #61
    Originally posted by kulokutoys
    thanks but same response
    Find hardware isues.
    Become a Badcaps supporter
    Thanks to all supporters.
    • Lornet
      • Mar 2021
      • 27
      • France
      #62
      T470s / Error 0288 / Black screen / External monitor working T470s_BIOS Dump_Error0288.zip
      Hello everyone and thank you for this forum (and in advance sorry if my post does not correspond to its rules)!
      My T470s worked well until I changed the screen (with a not compatible?). After that, a series of beeps rang at startup (code 0288 with Lenovo PC Diagnostics) and the screen remains black... I put back the original screen, changed the cable connecting the screen to the motherboard without any improvement. Today, I can still use the T470s but with an external display...
      I'm sending you the bios dump in the hope that it gets corrupted.
      Thank you in advance for your answers and repairs.
      T470s/ 20HG-S3DV00/ PC-0T0JKN​
        Vesko356 commented
        Editing a comment
        If the laptop is outputting an image on external monitor but not in screen itself you have a hardware fault not a bios problem.
    • Lornet
      • Mar 2021
      • 27
      • France
      #63
      Hello Vesko356,
      Thank you for your answer. That's unfortunately what I was afraid: the change of motherboard to anticipate...
      Sincerely​
      • Jasveer5277
        • Feb 2023
        • 7
        • India
        #64
        lenovo t470s m.2 ssd not detect help to solv this error
      • Kodza
        • Jun 2016
        • 173
        • South Africa
        #65
        Hello guys I got Lenovo T470s S/N PC-0UH2NJ, TYPE 20JT, main board NM-B081 Rev 1.0. When you switch on the laptop it's taking about 1 minute to display and the me vrsion is 11.8.93.4323. I have tried to do clean me but still it's taking long to display so I need help to clean ME. Here is the file Thanks
        • hoaca388
          • Jan 2022
          • 11111
          • Viet Nam
          #66
          T470s Laptop (ThinkPad) - Type 20JT
          • MonkeydBrian
            • Oct 2021
            • 17
            • south Africa
            #67
            Hi i got a Lenovo T470s with password lock can someone please assistant me in unlocking it for me as I've tried to use Lenovo_autopatcher to no luck. Thanks
            S/N PC-0UH2P7 18/05​
            • peste
              peste commented
              Editing a comment
              merged post..
          • hirens
            • May 2022
            • 170
            • uganda
            #68
            guyz hope your well,
            i have a lenovo T470s that runs only the fun, backlit shows but i have no image.
            board n0: DT471 NM-B081 rev 1.0
            s/n:pc-0uc03b
            type: 20hg-s3t900
            kindly jhelp me with a new file
            old one attached
            • hoaca388
              • Jan 2022
              • 11111
              • Viet Nam
              #69
              s/n:pc-0uc03b
              type: 20hg-s3t900
              old one attached
              T470s Laptop (ThinkPad) - Type 20HG
              • dennis akumu
                • Mar 2018
                • 96
                • kenya
                #70
                Lenovo T470S No display issue need a clean me file
                S/N- PC-0SN4TW 18/01 Type 20HG-S15V00
                BOARD NO- DT471 NM- B01 REV 1.0
                attached is the backup original file.
                please help to clean this file.
                • hoaca388
                  • Jan 2022
                  • 11111
                  • Viet Nam
                  #71
                  T470s Laptop (ThinkPad) - Type 20HG​
                  • T4-BR
                    • Sep 2024
                    • 6
                    • France
                    #72
                    Something went wrong after a BIOS (ME/TPM?) update, I'm getting error 0832 at boot.
                    Shutdown from Windows don't work. Sleep mode put the PC in a weird state where the beep code for 0832 is played if I try to power it on.
                    I also don't have access to the Security Chip from BIOS anymore...
                    S/N : PC0TZQ3L 18/04 Type 20JT-SGA0J0T
                    Could you please check my BIOS backup, to see if something is wrong ?
                    If you think that I missed something in the procedure, let me know!
                    Thank you !!
                    • jeremyhb
                      • Oct 2024
                      After resetting the secure boot keys, my T470s is in a perpetual reboot cycle.
                      It briefly shows the message "Configuration changed - Restart the system." before each reboot.
                      My issue is identical to the one mentioned in this reddit post: ThinkPad T470 not booting after Secure Boot Key reset
                      ​Is this an issue that can be fixed with the methods in this forum?
                      • jeremyhb
                        • Oct 2024
                        To answer my own question -- YES!
                        I dumped the firmware using a Raspberry Pi, an SOIC8 clip, and flashrom.
                        I "reverse engineered" what hoaca388 did for huss584's firmware dump in post #20 of this thread.
                        EUFITool was very useful in that process but unfortunately I couldn't use it to fix my firmware. The old version with editing capabilities doesn't understand the firmware for the T470s (or at least not the section that I needed to edit.) And the new version of EUFITool doesn't yet have editing capabilities.
                        Instead, I just used a hex editor (imhex is great) and overwrote the necessary sections manually.
                        I then wrote the edited firmware to the chip. On the first boot I went in to the UEFI and loaded the defaults settings and set the date/time.
                        And my laptop is back from the dead!
                        • 4G comm
                          • Sep 2021
                          • 48
                          • kenya
                          #75
                          [QUOTE=hoaca388;n1716638]Re: Lenovo ThinkPad T470s BIOS
                          Originally posted by husnu16
                          This really saved me....i programmed this bin file to my bios chip...flushed my lenovo 470s...but got stuck at entering setting.....i removed the bios bin...programmed back my original dumped bin file......and ALAS NO PASSWORD
                          much love from NAIROBI KENYA
                          • fredyjbi
                            • Feb 2021
                            • 144
                            • malaysia
                            #76
                            please help friends T470s turns on without display, fan spins fast, thank you, I've cleaned me but it's still the same
                            • peste
                              peste commented
                              Editing a comment
                              post merged..
                          • hoaca388
                            • Jan 2022
                            • 11111
                            • Viet Nam
                            #77
                            Serial number must be written out, not accepted as file name.
                            • fredyjbi
                              • Feb 2021
                              • 144
                              • malaysia
                              #78
                              Sorry sir, I'm late in replying because I just came back from out of town, this is the serial number, sir, T470S Type(20JT) SN PC-0NDYG8, thank you, sir.
                              • hoaca388
                                • Jan 2022
                                • 11111
                                • Viet Nam
                                #79
                                Where is a non clear Me file ?
                                • fredyjbi
                                  • Feb 2021
                                  • 144
                                  • malaysia
                                  #80
                                  [QUOTE=hoaca388;n1680133]Re: Lenovo ThinkPad T470s BIOS
                                  Originally posted by huss584
                                  T470s (type 20HF, 20HG) Laptop (ThinkPad) - Type 20HG
                                  Serial number : PC0RYF1J
                                  thank you very much sir
