Originally posted by kalilinux25
View Post
Hp probook 640 g1 bios
My final solution to repair bios and restore original motherboard specific data:
1. program bios chip with dump from post 249 -> bios does not contans machine specific data
2. after powering on the motherboard it gives some error messages like in post 250 about the missing data, however it is possible to launch Windows
3. when Windows is up, apply BIOS Configuration Utility from post 254 in the following way:
3.1 start CMD as admin and,
3.2 use BiosConfigUtility.exe /get:"actual.txt" command to write all available tokens / variable into actual.txt file
3.3 use BiosConfigUtility.exe /setvalue:"token from actual.txt","new value" command -> e.g. BiosConfigUtility.exe /setvalue:"SKU Number","G3K60EZ#AKC" will program G3K60EZ#AKC as SKU
3.4 repeat step 3.3 until you set all required tokens.
In my case theese were: Product Name, SKU Number, (ENTER) Feature Byte, (ENTER) Build ID, Serial Number, Product Family, System Board CT
3.5 when finished use BiosConfigUtility.exe /setvalue:"Manufacturing Programming Mode","Lock" to lock your bios
4. shut down Windows
5. power up your machine and it should start without any warning
Thanks everyone for your help!Last edited by szakacsa195; 12-18-2023, 03:49 AM.
