Hp probook 640 g1 bios
    Originally posted by kalilinux25 View Post
    please try this and report
    Thanks! Finally I did not test it, since this dump does not cointains my motherboard specific data.
      My final solution to repair bios and restore original motherboard specific data:
      1. program bios chip with dump from post 249 -> bios does not contans machine specific data
      2. after powering on the motherboard it gives some error messages like in post 250 about the missing data, however it is possible to launch Windows
      3. when Windows is up, apply BIOS Configuration Utility from post 254 in the following way:
      3.1 start CMD as admin and,
      3.2 use BiosConfigUtility.exe /get:"actual.txt" command to write all available tokens / variable into actual.txt file
      3.3 use BiosConfigUtility.exe /setvalue:"token from actual.txt","new value" command -> e.g. BiosConfigUtility.exe /setvalue:"SKU Number","G3K60EZ#AKC" will program G3K60EZ#AKC as SKU
      3.4 repeat step 3.3 until you set all required tokens.
      In my case theese were: Product Name, SKU Number, (ENTER) Feature Byte, (ENTER) Build ID, Serial Number, Product Family, System Board CT
      3.5 when finished use BiosConfigUtility.exe /setvalue:"Manufacturing Programming Mode","Lock" to lock your bios
      4. shut down Windows
      5. power up your machine and it should start without any warning
      Thanks everyone for your help!
        Need compleet new bios file for this laptop.
        Have new chip purchased and will use CH341 programmer
        Old bios data is not available.
        I have read that a serial number must be entered in the new BIOS.
        Read a lot but it is not completely clear to me with Google translate.
        How can I best approach this?
        Thanks,
        Marcel from the Netherlands
        sorry here the s/n: 5CG43200RT
          I've come a lot further.
          I use NbDmiFit-2.07
          I have entered the information that I think should be included
          But keeps giving 2 messages.
          1. Product family
          2. System board CT Number
          (I did fill this in)
          Who wants to help me on my way because I can't get any further now.
          I'm trying to add photos.
          Thank you in advance
          Part config file:
          BIOSConfig 1.0
          ; Originally created by BIOS Configuration Utility
          ; Version: 4.0.32.1
          ; Date="2024/05/02" Time="04:22:03" UTC="2"
          ; Found 226 settings
          Manufacturer
          Hewlett-Packard
          Product Name
          HP Probook 640 G1
          System Board ID
          1993
          Product Family
          HP Probook 640 G1
          SKU Number
          A3009DD10203
          Notebook Model
          D9R53AV
          System Board CT Number
          PEBGU00WD7A5RWCZI
          Serial Number
          5CG43200RT
          Product Number
          D9R53AV
          Universally Unique Identifier (UUID)
          FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
          Processor Type
          Intel(R) Core(TM) i5-4200M CPU
          SKU Number
          H5G68EA#ABH
          Warranty Start Date
          00/00/0000
          Processor Speed
          2.50GHz
          Sunday
          *Disable
          Enable
          Monday
          *Disable
            Laptop is ready again.
            I didn't know exactly what to fill in because there were no labels attached.
            After a very long search on how to build the config file, we succeeded.
            Data from other 640 g1 uses a mix. haha
            Still missing a SKU number but found it.
            The config of the bios was very easy to adjust and fill in the missing data in "MPM TOOL" for Windows!!
            You read the current config in Windows and after editing you write it back.
            Finished!
            Put the working text file into youre bios chip.
            Maybe adjust
            No more annoying error messages at startup
            Hopefully this will also help other people now.
            Good Luck!
            Appendix:
            MPM tool
            Working bios file
