Toshiba password
  • ALEXV90
    • Jul 2025
    • 5
    • México
    #961
    Please I need help for my Toshiba that has password
    Toshiba Tecra a11
    Serial number: 9A163205H
    Challenge code: RJAW0-N2YEB-7EJCN-EF11N-VRV96
    RESPONSE code:???????
    Thank you
    • wEDpaYes
      • Jul 2025
      • 10
      • Ukraine
      #962
      Originally posted by wEDpaYes
      Hello again.
      I'm very sorry for the inconvenience, but unfortunately I couldn't enter the response code in time.
      My Toshiba tablet-laptop suddenly overheated and froze on the password screen. I was unable to type anything, as it became completely unresponsive.
      I've since carefully disassembled the device to prevent this from happening again and it's now running much more stable.
      I would truly appreciate it if someone could help me by generating a new response code based on the following challenge:
      Model: Toshiba PORTEGE WT20-C
      PC Serial No. = YH099093H
      Challenge Code = 8H0VB-4992B-XPBH9-J1YVY-TXVPK
      Response Code =
      Thank you so much in advance for your time and patience — I greatly appreciate this amazing community's support!
      I’d like to kindly inform you that my device has remained powered on and responsive since July 29, 2025, at 12:40 PM, and it has not frozen or shut down during this time.
      Unfortunately, I was unable to enter the previous Response Code in time, and I sincerely apologize for any inconvenience this may have caused.
      Would it be possible to kindly provide a new Response Code? I would greatly appreciate your support.
      Thank you in advance for your understanding and assistance.
      • Tech@Lap
        • Aug 2022
        • 21
        • Samoa américaines
        #963
        try this :
        Generated Response Code
        Serial Number: YH099093H
        Challenge Code: 8H0VB-4992B-XPBH9-J1YVY-TXVPK
        Response Code: 6S222-AT7XA-QPKQX-LQPQG-JQWVM
        • evserv
          • Jun 2014
          • 360
          • Russia
          #964
          Toshiba Tecra a11
          Thank you
          Response Code = WC6EW-81GU8-6GCT1-H3WEF-2X8YQ
          • wEDpaYes
            • Jul 2025
            • 10
            • Ukraine
            #965
            Originally posted by Tech@Lap
            try this :
            Thank you very much for providing the Response Code.
            I carefully entered it on my device and made sure everything was correct. I double-checked the input and can confirm that I didn’t make any mistakes. Unfortunately, the code did not work, and since there is only one attempt allowed, I was not able to try again.
            I would be truly grateful if you could assist me further or possibly provide a new code.
            Thank you again for your time and support.
            • wEDpaYes
              • Jul 2025
              • 10
              • Ukraine
              #966
              Thank you once again for providing the previous Response Code.
              I carefully entered it and verified everything to ensure there were no mistakes. Unfortunately, the code did not work. As there is only one attempt allowed, I was unable to retry.
              If it’s not too much trouble, may I kindly ask you to generate and provide a new Response Code? I would greatly appreciate your help.
              Challenge Code = L65K2-JRMPJ-EQFQA-BRXHR-912PC
              Response Code =​
              Thank you very much for your time and understanding.
              • evserv
                • Jun 2014
                • 360
                • Russia
                #967
                Response Code =
                Response Code = FE421-LBD4U-MYEFD-81QG3-RWQER
                • Tech@Lap
                  • Aug 2022
                  • 21
                  • Samoa américaines
                  #968
                  Response Code =
                  Challenge Code: L65K2-JRMPJ-EQFQA-BRXHR-912PC
                  Response Code: EEA98-66EBC-E2242-405D7-AB7DF​
                  • evserv
                    • Jun 2014
                    • 360
                    • Russia
                    #969
                    What's the point of publishing codes that don't work...you give people false hope
                    You provided more than 10 codes and none of them work.
                    Your generator makes incorrect codes.
                    • wEDpaYes
                      • Jul 2025
                      • 10
                      • Ukraine
                      #970
                      Thank you again for your assistance and for providing the previous Response Code.
                      This time, my device behaved differently than before. After I entered the code, it didn’t display any message or error sound. Instead, it simply rebooted on its own — but unfortunately, the BIOS password was still there afterward.
                      I'm not sure what might have caused this, so if you have any insights into what this behavior could mean, I would truly appreciate your advice.
                      If possible, I would be very grateful if you could kindly provide a new Response Code so I can try again.
                      Challenge Code = AD7FH-CY7CQ-FAWG3-R1F45-GT0QB
                      Response Code =
                      Thank you so much for your continued help and support.
                      • evserv
                        • Jun 2014
                        • 360
                        • Russia
                        #971
                        Response Code = E59F4-DBC8L-LEUNL-HWU2Y-YVYE4
                        Study the instructions carefully and follow all the steps described in them.
                        If you made a mistake somewhere, then the problem is yours, since the code is one-time.
                        • wEDpaYes
                          • Jul 2025
                          • 10
                          • Ukraine
                          #972
                          I just wanted to let you know that the code actually worked!
                          It seems that after entering the code, the key was to press F2 as the device began rebooting. Once I did that, I was able to access the BIOS, and the password was successfully cleared.
                          Thank you so much for your support and for providing the code — your help is truly appreciated!
                          • Tech@Lap
                            • Aug 2022
                            • 21
                            • Samoa américaines
                            #973
                            I see that, you have a working code .
                            • PStobo
                              • Jun 2025
                              • 7
                              Hi, I am back. I picked up a Tecra 840r for my wife (just like mine). Last time I was a complete noob. I posted a picture that was not asked for and typed the challenge code wrong. Evserv generously spotted the mistake (thanks again). This time I had the wife double-check my work.
                              PC Serial No. = 5B083293H
                              Challenge Code = 7X5DU-N78NP-6WUCK-79HG5-7E814
                              Thanks in advance,
                              Philip
                              • Peter London
                                • Jul 2025
                                • 3
                                • United Kingdom
                                #975
                                Good evening,
                                Is there a response code for...
                                {"Serial":"YG139866H","Challenge":"TcUCxMGXd8DlAm5Tcz4OhM7ECZEAtndHCBBnQ4qxligbFmRt4WIWKQcFpD8ZcHHevJScMcplogwcW1QyLdoKEOI9KFVaouhPp5ZDMP7F8jT6mZZkEXjsQV7UbyOF6fKTNfjNfAQoLgbAC6e6FBKrLrpFdE79EXmhh4zHuIhCJzVI286tbBgvlgLXQJ67CWuuRVn0nFjzLydlbVHDTwPxz2TVTjfuH7sJEwve5NC4vTjQ4cyTS0xBElKDm6FmlRFF0kecNpoSU5rBwGIVg3lZ14PC68hhC5gvw4qxXl1o4KaRpyBeaPUm2GgV7dmxi1NfCAcMDkSa6HxnZHEs6DlG1ezB7xBOwtZV2NvuwVJZDfbHaS01aZXn"}
                                how can I get a "standard" challenge code?
                                Thanks in avance!
                                • jamesemmanuel
                                  • Aug 2025
                                  • Nigeria
                                  #976
                                  hello
                                  am new i wish to be good with all friend here .
                                  i need help
                                  PC Serial No. = 2H042834H
                                  Challenge Code = CBYME-FWPH3-6MBJU-ER3KB-4AQXD
                                  Response Code =
                                  thanks in advance
                                  • Dericktechdepot
                                    Derickali
                                    • Aug 2025
                                    • PHILIPPINES
                                    #977
                                    Hi I am a new member please help me to get a response Code for the Toshiba Laptop
                                    PC Serial No. 2E172168H
                                    Challenge Code: 86K1W-6GH72-AXH12-G4FVH-GDCUW
                                    • Farid2000
                                      • Jul 2023
                                      • Afghanistan
                                      #978
                                      hi help pls
                                      serial No. : 4F017251H
                                      Challenge Code: D7HW8-DP18E-93D6E-ECRC2-PCHEA
                                      RESPONSE code=?
                                      • eduardo143
                                        • May 2020
                                        • Panamá
                                        #979
                                        hi..ayúdame por favor necesito el response code
                                        Pc serial: 1B034462H
                                        CHALLENGE CODE: QNPLD-W6FRY-6PG3Q-0DX9U-UGPY2
                                        DESDE PANAMÁ
                                        MIL GRACIAS
                                        Hi, please help me. I need the response code.
                                        PC serial number: 1B034462H
                                        FROM PANAMA
                                        THANK YOU SO MUCH
                                        in English please...
                                          Toshiba Tecra Tecra X40-E-114 Netbook Specification for Upgrade or Repair
                                          This specification for the Toshiba Tecra Tecra X40-E-114 Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Tecra X40-E-114 boardview and Tecra X40-E-114 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 06:42 AM
                                          Toshiba Tecra C50-E-1VU Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Tecra C50-E-1VU Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C50-E-1VU boardview and C50-E-1VU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          09-06-2024, 03:21 PM
                                          Toshiba Tecra C50-E-1VM Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Tecra C50-E-1VM Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C50-E-1VM boardview and C50-E-1VM schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          Toshiba Tecra C50-E-0C2 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Tecra C50-E-0C2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C50-E-0C2 boardview and C50-E-0C2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          Toshiba Tecra C40-D-00D Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Tecra C40-D-00D Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C40-D-00D boardview and C40-D-00D schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          09-06-2024, 11:50 AM
