Toshiba password
    Originally posted by sozmen View Post
    QUOTE=evserv;n3247727]
    Response Code = P1AFN-J26PY-QF1Q4-A71AH-1G1RA
    If more easy for you, I just sent my **********************************[/QUOTE]
    BIOS request section has been getting a little bit wild lately, therefore we need to be more strict with the rules, both for people requesting help and people offering help.
    — You are requesting help
    If you do not abide by the following rules, your post will be deleted.
    You MUST NOT:
    • Hijack threads unrelated to your request
    • Post a request in multiple threads
    • Post a request multiple times
    • Post in foreign (non-English) languages
    • Share private contact information
    • Offer payment of any kind whatsoever
    • Bump your thread or post more than once every 48 hours. If you do so
      you will receive an infraction
    • Post "clean me", "clear bios", "clean bios", "fix bios", "bios need", "clear me" or other such terms
    You MUST:
    • Read BIOS guides, methods, resources and tools
    • Try the method at BIOS guides, methods, resources and tools before requesting help
    • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
    • Use search function in case someone already answered your request
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
    Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
    — You are offering help
    Please remember that no one is forcing you to provide help on this forum. If you are willing to help without anything in return, you are highly encouraged to do so. If you are not, then this is not the place for you.
    If you do not abide by the following rules, your post will be deleted and you will be banned for anything related to commercial offers.
    You MUST NOT:
    • Attempt to sell anything
    • Post external link to paid or registration only website (incl. in archive)
    • Post passworded archive
    • Post unsolicited self-advertisment
    • Nag people with solutions you are not willing to share
    • Do business in private messages
    • Seek businness opportunities
    • Openly ask for donations
    • Post software with malware
    • Post homemade software breaking any of these rules
    • Willingly post misinformation
    • Ask for or accept payment of any kind whatsoever
    You MUST:
    • Post the source code of any homemade software¹
    ¹. There are been multiple controversies about software developed by the community in the past. In order to avoid it happening again and support sharing the actual knowledge, source code will be required for any future software developed by the community. Source code will be highly appreciated for any existing software or for online software (SaaS type). In case of any suspicion of broken rule for existing software or online software, the software may be removed if the source code is not released.
      Originally posted by evserv View Post
      Your hard drive is locked, remove it and try without it.
      Thanks for fast answer.. I removed the hard disk. I changed the bios battery. I connected the device to UPS against power outages. Now a new challenge code is below.
      PC Serial no: 18069737H
      Challenge Code: GJDAX-529MN-7W3EN-6XYVD-C8PFA
      Model: Toshiba Tecra S5
      I would be pleased if you give the response code, this time when you enter the bios, it will say 'registered' in the password section, as before. But I won't be able to see the password. If it asks for a password again when you save and exit after changing the date and time, we will go back to the beginning. Because in the previous attempt, I entered 4 0s (0000) where it said 'registered', I registered it, but when the device was turned off and on, it asked for the password again and did not accept 0000. We need to remove the actual password prompt.
      If I can get a quick answer, I will share the screenshot after logging into the bios here and we will continue step by step. The resource remains here for those who will use it later.
      Click image for larger version  Name:	image.png Views:	0 Size:	90.0 KB ID:	3248396
        Response Code = XGE93-QDQKE-058RX-M8540-0ET22
        Please read the instructions carefully before entering the code.
        It's your last try...
          First of all, thank you for your help. The steps were different from the steps in the user manual, so it didn't work again. I'm sharing it here to keep it as a resource.
          As you know that, I removed HDD before.
          I entered the response code you gave, the following screen appeared,
          Click image for larger version  Name:	image.png Views:	0 Size:	172.5 KB ID:	3248796
          Here I answered the Y/N question as Y and the following screen appeared,
          Click image for larger version  Name:	image.png Views:	0 Size:	230.0 KB ID:	3248797
          Then I pressed the enter button and the device turned off and turned on again, the following screen appeared,
          Click image for larger version  Name:	image.png Views:	0 Size:	35.0 KB ID:	3248798
          and then went back to the beginning and asked for the password again.
          Click image for larger version  Name:	image.png Views:	0 Size:	24.4 KB ID:	3248799
          I mean, I couldn't even get to the steps in the user manual.
          However, in my previous attempt, after pressing the Y key, the device entered the bios screen. If I had this document at that time, I could have achieved this.
          I had this screen in my previous unsuccesful attempt, I was able to enter the bios screen you mentioned by pressing the F1 key, this time it did not come here.
          Anyway, I'm sorry, thank you for your efforts,🙏 I made you tired. I'm giving up now.😌
            hi
            I need help with challeng code Toshiba satalait Pro R50-B
            I did the instraction
            run laptop press f2 and then contrl tab control enter
            thanks in advance
            Motherborad number is : A5A003954010 A , FAEBSY2
              Hi everyone I have the Toshiba Tecra R950-11F which is bios locked by a supervisor password. If anyone can help please respond so i can get the challenge code and serial number.
              I can't get these codes as I am using the laptop alot and would have to restart it after the codes have been provided.
              Thanks all
                Hi, Can anyone generate a response code for me please
                PC Serial no: 3F139759H
                Challenge Code: 7HL7M-UP4B8-B053R-CGX8P-B6M95
                Thanks .
                  please need toshiba responce code
                  SN:ZF136915H
                  Challenge code: 467QN-7WL89-LQ5LA-U8DAX-U5WVQ
                    Please help unlock my laptop
                    PC=Toshiba Tecra R950
                    Serial : XD607101G
                    Challenge Code = C9TN0-K6XQT-DU5HJ-8B6G3-RHR1F
                    Response Code = ?
                      any help plzz
                      PC Serial No. = 1D043150H
                      Challenge Code = FV2KN-6JVYX-MLBEH-LEX1F-9D3WE
                        Please help with the following (dinosaur) laptop:
                        PC Serial no: 65898810G
                        Challenge Code: 438P0-19A5B-FW3RD-381GC-H56CR
                        Model: toshiba qosmio g20 102
