Needed Bios Dell Precision 5530 password
This topic is closed.
  • volinakis
    • Jan 2021
    • 2747
    • N/A
    #61
    Re: Needed Bios Dell Precision 5530 password
    Originally posted by FjordFisch
    Thank you very much for your great support. The unlocked BIOS worked perfectly.
    Just a remark: I used the NeoProgrammer 2.2.0.10. In the first attempt after flashing the new BIOS the passwords were still in there, and the compare function showed differences. NeoProgrammer likely skips all 0xff areas in the buffer to reduce programming time, so it doesn´t overwrite the password areas. I had to clear the flash memory before programming. After this the compare function showed no differences to the buffer anymore.
    using CH341A and compatible software you have to erase 1st bios chipset then write it with .bin file. Or check box "auto-erase" in settings.
    • mandrake87
      • Jun 2022
      • 70
      • argentina
      #62
      Hi, good, I have a 5330 with adsolute enabled and it cannot be disabled, how would I do it? I leave my bios dump
      • volinakis
        • Jan 2021
        • 2747
        • N/A
        #63
        yours is Latitude 5330, not Precision, post your request to proper thread.
          • 21186
          You MUST:
            • 21186
            Thread closed
            • mizzed
              Bios Request - Dell Precision 5530 2in1 LA-F211P rev 1.0 - updated
              by mizzed
              Hi, Would anyone have a bios dump for a Dell Precision 5530 2in1 LA-F211P rev 1.0.
              Following a failed bios, I had a new bios chip programmed with the the XPS 15 9575 2in1 LA-F211P rev 1.0, which the motherboard has identical model numbers, (having not being able to find a 5530 2in1 bios) however both in bios and os, the Vega graphics, and sound boards are not detected or installable, everything else worked fine. The only difference I can see is that although the motherboards are nearly identical is that they have slightly different CPU/GPU 8705g vs 8706g.
              If anyone...
              01-05-2023, 06:53 AM
            • trix11
              Dell Precision T1650 MT Workstation bricked after BIOS update
              by trix11
              I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
              - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
              - Dell Precision T1650 mid tower Workstation
              - Xeon E3-1225 V2
              - 32Gb PC3-12800E RAM
              - 4Tb SATA HDD
              - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
              I see now that others have experienced like issues e.g.:
              - https://www.dell.com/community/Prec...
              10-24-2022, 10:35 PM
              DELL Precision 5530 Mobile workstation 5000 Specification for Upgrade or Repair
              This specification for the DELL Precision 5530 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5530 boardview and 5530 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Precision...
              09-06-2024, 05:30 PM
              DELL Precision 5530 Mobile workstation 3000 Specification for Upgrade or Repair
              09-06-2024, 03:30 PM
