DELL latitude 7390 bios dump
    Hi i need bios for dell latitude 7390 i5 gen8th
    Re: DELL latitude 7390 bios dump
    Old bios problem?
      Originally posted by imranromi View Post
      Old bios problem?
      password problem
      motherboard model
      daz20 la-f312p rev 1.0 (a00)
        my bios with password
          Try this and post results.
            It's working. Thank you
              When program you add service tag new?Means asking you service tag add new
                Can you fix this bios (this one is oke bios with me clear), i want bios with empty service tag and can add NEW svtag when first power on
                  try this..
                    Originally posted by peste View Post
                    try this..
                    Thank you peste!
                      try this..
                      Thanks but it detects it as 7290 not 7390, but works
                        try this..
                        Can you change so that i can choose the model?
                          @grzechqu
                          You just need to unlock the BIOS correctly, you won't have to edit anything!! Everything above is wrong!!
                            i bought a used latitude 7390 (C1WCVT2-E7A8) and want to reset the bios. If I upload a bios backup using "Bios backup toolkit", would I be able to use the same tool to update the bios using a fix (hopefully) provided by a member of this forum?
                              @schiff
                              It is not necessary, just enter the master password correctly.
                              Try the first password, if that doesn't work, use the second password.
                              PASSWORD #1
                              DELL Service Tag: C1WCVT2-E7A8
                              password: yGk6k2kqqNyqpNMr
                              PASSWORD #2
                              password: LJkB1b7mMRPrNMsz
                              Type the 16-character password. For UPPERCASE characters use SHIFT key.
                              Once you are done typing password, hold down left CTRL key and press ENTER key *twice* (CTRL-ENTER-ENTER).
                                @onizzbox,
                                This worked! thank you!
                                  @onizzbox,
                                  Very good! enjoy the laptop !!
                                    Hello.
                                    Im new here and I would ask question.
                                    NB Dell 7390 - DAZ20 la-f312p rev 1.0 (a00)
                                    My colleague spoiled coffe on NB and stop working.
                                    I repaired this NB with isopropyl wash and works witout any problem and return to my colleague.
                                    This stupid upgrade firmware with incorrect/different model and NB died again.
                                    i used ch341a programmer and revieve NB again, but shows as 7290 and no TPM on boot.
                                    Any idea with this problem? I tried all possible bios from dell without success. Always boot and need press F1.
                                    TPM dissapear from bios and under windows/powershell show TPM not present. Dell utilities not working, but If I use util from different model, show me version TPM 7.2.0.2 and if I press Next, just show me all is updated.
                                    Any idea how to fix TPM? I dont want throw this NB to bin or replace motherboard.
                                    Thank you for any advice.
                                      Originally posted by Pivan View Post
                                      Hello.
                                      Heres something https://mrtechbot.wordpress.com/2019...tialize-error/ .Try the suggestions and let us know if something works for you.
                                      • ELECTRONICA JR
                                        ELECTRONICA JR commented
                                        Editing a comment
                                        FIX PROBLEM ALERT TMP NO DETEC
                                      Tried everything and not works Probably only solution is change motherboard.
                                      Or I will wait for new bios update if come and try again.
