Dell 7480 LA-E132P Plz Solve late display
  • ace.code
    • Apr 2016
    • 133
    • Estonia
    Dell latitude 7480 bios
    i need bios for dell latitude 7480
    CAZ20 LA-E132P REV :2.0 (A01)
    I DONT HAVE THE ORIGINAL DUMP
    • peste
      • 12859
      • ROMANIA
      Re: Dell latitude 7480 bios
      https://www.badcaps.net/forum/showthread.php?t=72866
      • ace.code
        • Apr 2016
        • 133
        • Estonia
        thnx i try it but pc take 15 sec to boot i tried clean me but still same problem
        • bachir2004
          • Feb 2015
          • 437
          • maroc
          me cleaned.
          • ace.code
            • Apr 2016
            • 133
            • Estonia
            Originally posted by bachir2004
            me cleaned.
            its works great but its password locked
            • ace.code
              • Apr 2016
              • 133
              • Estonia
              #26
              just used password generator thnxxxxx everything is ok
              • alihomee
                • Dec 2012
                • 1576
                • malaysia
                #27
                dell latitude 7480
                display is so late mobo code is CAZ20 LA-E132p
                • peste
                  • 12859
                  • ROMANIA
                  #28
                  Re: dell latitude 7480
                  the posted bios has been cleaned once more..try
                  • JersonP
                    • Mar 2020
                    • 29
                    • mozambique
                    #29
                    Re: Clean me dell latitude 7480
                    Cleam me
                    • MAZMAZ22
                      • Jul 2016
                      • 68
                      • ALGERIE
                      #30
                      his bios dump and it take too long to show the dell logo so can anyone clean me this dump :ré
                      • peste
                        • 12859
                        • ROMANIA
                        #31
                        try..
                        • FShahid
                          • Nov 2012
                          • 57
                          #32
                          me cleaned.
                          Hi, I think I did a big mistake by flashing above file without checking full motherboard revision, mine is REV : 1.0 (A00). Here is the full story below:
                          So basically, it took 15 seconds for each POST but it also seemed that BIOS is read-only because anything I try changing in BIOS won't save any changes, not even custom UEFI boot paths and also no connected USB shows in F12, flashing using CTRL + ESC was also failing with "Firmware failed..."
                          But it could still boot to windows so I did the pinmod trick to unlock FD and then flashed this quoted bios file.
                          It flashed fine but then after reboot it no more shows Dell logo or any other text except it shows a blinking prompt and reboots and keep doing that.
                          Let me know if there is anything can be done without using chip programmer as I don't have that.
                          PS.
                          I have a spare BIOS chip from another broken laptop which I tried swapping (before trying to flash above file) but it was also showing exactly same symptoms AND cannot boot to windows because it won't let me save boot location. I can swap it back if there is any hope passing beyond POST.
                            • 20984
                            Re: Dell 7480 LA-E132P Plz Solve late display
                            You can`t unlock the FD using that method anymore with newer models,and modified grub boot doesn`t work. Buy a programmer,the ch341a only costs around 3 quid delivered. If you buy a black pcb version do the 3.3v mod and use NeoProgrammer,AsProgrammer,Colibri or flashrom software with it https://www.badcaps.net/forum/showpo...50&postcount=5 .Dell post bios updates per model,not by motherboard revision.
                            • FShahid
                              • Nov 2012
                              • 57
                              #34
                              Not sure if I understood but I was able to have full access to EEPROM whilst in Windows and used Intel FPT tool to flash said file without any errors. Had to do the pin 1 and pin 5 jumper on audio chip at power on to achieve that. Intel Management Engine was not shown with or without pinmod in Device Manager so that's why I started following this method.
                              Now if I have another go replacing UC5 BIOS chip with another one I have (but that is also shown read-only so cannot set boot path to boot windows). Is there any way I can fix it?
                              According to this source: https://downloads.dell.com/manuals/c...uide_en-us.pdf I suspect the UC1 (PCH) is faulty as interestingly when I first tried to replace BIOS initially everything in BIOS was changeable but after a second time in BIOS every option was greyed out (read-only) which is why I replaced back the BIOS chip.
                              • akis1
                                • ankara
                                #35
                                Try this one .
                                ok Thanks
                                • mnciks11
                                  • Aug 2019
                                  • 345
                                  • south Africa
                                  #36
                                  Hello guys
                                  I have Dell 7480 LA-E132P rev 2.0 that has a password on it, tried the files on this thread but non of them work
                                  SERVICE TAG (S/N) : 6RY1HM2
                                  • peste
                                    • 12859
                                    • ROMANIA
                                    #37
                                    Originally posted by mnciks11
                                    Hello guys
                                    try..
                                    • mnciks11
                                      • Aug 2019
                                      • 345
                                      • south Africa
                                      #38
                                      Thank you so much man
                                      The file is working
                                      • mnciks11
                                        • Aug 2019
                                        • 345
                                        • south Africa
                                        #39
                                        Hello guys
                                        I need a working bin file for Dell Latitude 7480
                                        CAZ20 LA-E132P
                                        REV 1.0
                                        Below is my EC and Main bios file
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 11798
                                          #40
                                          Hello guys
                                          CAZ20 LA-E132P
                                          REV 1.0
                                          Latitude 7480
                                            DELL Latitude 7480 Notebook 7000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 7480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7480 boardview and 7480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7480...
                                            09-06-2024, 08:01 AM
