Acer Aspire E5-772-89L4 Bios needed
  • Blackcoiin
    • Feb 2019
    • 55
    Hello friends,
    I have a laptop lying here, which does not show me a picture. The fan is spinning, the drive is running but it does not start.
    Can someone fix me for this model my bios? It is a relatively new device and it would be a pity if I had to throw it in the garbage. The model is Acer Aspire E5-722-89L4 Model NR: N15W2
    Motherboard Name: Franky_CZ MB
    14278-2
    448.04Y03.0021
    Many thanks in advance.
    Oh, is there any way to support this forum through donations?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Acer Aspire E5-772-89L4 Bios needed
    Your bios is definitely corrupt or you have made a improper backup. Is the chip 1.8V?? The acer website update file is bit strange so i coulnt figure out how to make that dump. Ending of the file i can find in the update but header i couldnt locate. Maybe some more experience members may help.
    • on/off
      • Oct 2016
      • 333
      • Indonesia
      Originally posted by Blackcoiin
      Hello friends,
      14278-2
      448.04Y03.0021
      https://www.badcaps.net/index.php?pageid=donate1
      I think Beginning of File was different if for Intel model. I believe this model for AMD platform.
      Also Owner poster had mistake mention the laptop model on title box (correct on content thread), should be E5-722 series, wasn't E5-772. For OP next time not hurry to post double check your own post. Good luck
      Note: If have issue when extracted, try use 7zip.
      • Blackcoiin
        • Feb 2019
        • 55
        hello guys, that unfortunately did not work with this bios. do you have an alternative? the fan does not turn at all, but after a few seconds it starts to turn on very high power. Thanks
        • on/off
          • Oct 2016
          • 333
          • Indonesia
          What code on top IC bios? 8mb or 16mb code?
            • 21692
            Post your serial number .
            • Blackcoiin
              • Feb 2019
              • 55
              The code on the bios Chip is the same like in the picture i uploaded.But the last numbers not 1511,rather 1618
              • Blackcoiin
                • Feb 2019
                • 55
                edit:
                  • 21692
                  Post your laptop serial number
                  • Blackcoiin
                    • Feb 2019
                    • 55
                    I am so glad that you want to help me, for this reason alone I will give this forum soon a big donation. Great forum! Great people!
                    • Blackcoiin
                      • Feb 2019
                      • 55
                      Serial number : Nxmy0eg0076370481a6600
                      snid: 63701845866
                        • 21692
                        Thanks, i wanted to check the serial on your laptop against the one in your bios backup as the E5-722 and E5-722G have a different bios
                        • Blackcoiin
                          • Feb 2019
                          • 55
                          I can also start the laptop via the power button. Switching off is not possible. I have to pull the power plug for that. As described, the fan does not run at startup, but then starts spinning very fast. The laptop did not go from one day to the next, so I think it's bios.
                            • 21692
                            Try this bios,your DMI info included .If this bios doesn`t work the problem is somewhere else.
                            D 60000 - 601FF
                            W 5CA000 - 5CA030
                            • Blackcoiin
                              • Feb 2019
                              • 55
                              @SMDFlea,
                              I'm sorry, but there is no file in your post?
                              Oh now i can see it ! Thank you my friend, i will give feedback in about 20 min.
                                • 21692
                                @SMDFlea,
                                There is now .
                                  • 21692
                                  @on/off sorry for interupting the thread, you were right about it being an AMD bios.Easy to get confused with acer part numbers.In your bios there was 1 small error at 5CA030 ,ive done that before too, missing the last character on the win key.
                                  • Blackcoiin
                                    • Feb 2019
                                    • 55
                                    small interrogation, is it normal that the programming can take up to 5 minutes? With this chip I noticed that it takes a long time to delete and program.
                                      • 21692
                                      It depends what your programming it with, but generally no. Maybe the bios chip is faulty, is it getting very hot .
                                      • Blackcoiin
                                        • Feb 2019
                                        • 55
                                        so I'll get back to you. unfortunately it still does not work. the chip will not get warm when programming or erasing. But it takes up to 5 minutes to program / delete. Should I maybe buy a new chip and then try again or is it something else? Same symptoms as before.
                                        • EbrahimSiami
                                          Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                                          by EbrahimSiami
                                          I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                                          **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                                          **What I have tried so far:**
                                          1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                                          07-02-2025, 02:31 PM
                                          ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 02:30 PM
                                        • NecroFlex
                                          Acer Aspire 1 A115-32-C28P BIOS needed please
                                          by NecroFlex
                                          I have an Acer Aspire 1 A115-32-C28P laptop that tries to boot for 5s and then shuts off. (Mobo name GH5JJ/GH7JJ LA-K701P Rev C1)
                                          I suspect the BIOS might be the issue, but ACER website doesn't come with a BIN file, only an EXE that doesn't contain the full image. I tried searching for a BIOS bin but no luck.
                                          I have attached both the bios i read from the chip and the latest ACER bios. Thanks for any help in advance!...
                                          02-11-2025, 08:51 AM
                                          ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
