Acer ES1-331
  • Conste
    • Oct 2018
    • 235
    Acer ES1-331
    Hey there,
    I need a bios for ACER ES-331-C8XF machine.
    Cannot find any on the net.
    Thanks in advance.
    Regards,
    Constantin
  • basemyounes
    • Sep 2017
    • 79
    • gaza
    Re: Acer ES1-331-C8XF
    Hi
    Welcome this you need
    • Conste
      • Oct 2018
      • 235
      Thanks mate :-)
      I guess I need a 1,8v programmer for this one?
      • basemyounes
        • Sep 2017
        • 79
        • gaza
        Originally posted by Conste
        Thanks mate :-)
        If you have adapter i can give you method how made it ok
        • Conste
          • Oct 2018
          • 235
          I bought an adapter already, can it be that my CH341A programmer does not autodetect the Gigadevice 25LB64CS chip?
          Regards,
          Constantin
          • Duranitron
            • Jul 2014
            • 544
            • Philippines
            Regards,
            Constantin
            just a suggestion, do you solder the 25lb64cs to the ch431 programmer or you use adapter clip? in using the adapter clip match the red wire to pin no 1 of the eeprom you can program the ic without pulling it out of the motherboard and try again or clean the ic pin for proper contact. hope this helps.
            Never stop LEARNING because life never stops TEACHING!
              • 20643
              Regards,
              Constantin
              If you open the bios with UEFITool you`ll see the different bios IC`s supported. Manually select one of the others if they`re supported by the CH341A ,theyre all cross compatible, or try it with AsProgrammer software ,choose W25Q64FW 1.8V
              Flash chips in VSCC table:
              EF6017 (Winbond W25Q64)
              C86017 (GigaDevice GD25Lx64)
              1C3817 (EON EN25S64)
              C22537 (Macronix MX25U64)
              • tugrul63
                • May 2015
                • 94
                • türkiye
                es1-331 bios need
                hi
                i need es1-331 bios dump
                motherboard: LAW_BA MB 14295-1M
                old bios https://www.badcaps.net/forum/attach...1&d=1647011929
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11620
                  Re: es1-331 bios need
                  Aspire ES1-331
